Results 1 to 3 of 3
Thread: VZ Trans HELP!!
    manualwagon is offline manualwagon
    Vl manual wagon, VS Statesman, 2007 Triumph Tiger.
    Jan 2007
    Mooroopna Vic
    Default VZ Trans HELP!!
    Daughter has a VZ alloytec commy that has developed a shudder/miss during acclereation and sometimes when just cruising and the car need a little more power on cruise for a hill etc. She has found that if she drives it thru the trans shifter,[manually] it doesn't do it.. We have had it on a scantool and there was nothing out of the ordinary, they suggested a set if plugs and a fuel filter, another place had similar probs but found a broken fibre optic cable in the computer. But it sounds like a tranny prob. Has enyone had any experience with a VZ like this? Help needed
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    VZ SV6
    Aug 2010
    Got a similar problem that others might be able to help with, sorry to bomb your thread..
    My vz sv6 5sp auto shudders when accelerating, similar to above, mainly in higher gears, push harder and it will change down and is fine.
    But here is the strange bit, use the active select and hold it in gears 3-5 and it will do it constantley, 5th being the worst and it's horrible..
    Any ideas?
    First thoughts was gear box, but could it be something to do with the throttle??
    Am going to drain the Auto oil and change the filter (Yeah I've read the thread and understand it's a K%$T of a job)... To see if that helps.,
    Any other help would be much appreciated.
  1. [NZ] l67 trans ecu and loom and subframe trade for 5l trans ecu,loom and subframe
    By Nzpure in forum Swap / Wanted to Buy / Trade
    Last Post: 21-04-2010, 09:51 AM
  2. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  3. vr - vs - vt trans are they the same
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 07:55 PM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
