Results 1 to 8 of 8
Thread: vz overflow reservoir
    vz acclaim
    Jun 2006
    Default vz overflow reservoir
    Hi i was wondering how hard it is to change a overflow reservoir in a alloytech i guessing mine is cracked or sumthing because when i top it up coolant pours out the bottom of the car any help would be great
    TEAM CLOWN RACING
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    if you try to overfill the reservoir it will spill the excess out.
    Are you sure your not trying to overfill it? That damn level check thing can be a pain to read.
    Bulldog Edd is offline Banned
    VZ SV6
    Feb 2012
    I think mine is cracked or a pipe has come off or something because mine was bone dry, as soon as I added water it pour out frum under the car
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Take the front bar off, then it's accessible
    Spoken by a true member of The Committee
    VZ LUMINA
    Mar 2012
    St Andrews
    could be any number of problems dude, hopefully just a hose has come loose, did you have a boilover or overheat at all?
    VZ SV6
    Feb 2012
    I had an brief overheat when I turned on the air con, but that was 3 days ago, now everytime I turn on the air con I dont get an overheat.
    Would anyone know what happened then? It wasn't an a real hot day if that helps.....
    VZ LUMINA
    Mar 2012
    St Andrews
    Coolant change
    there is a 4 pg document in this thread regarding a flush, this will help you refill both the reservoir and the main radiator tanks then check if you still have a leak. and where it may be coming from.
    hope it helps.
    also, depending on where the leak is, it may only leak when the engine gets hot enough to squirt the water out under pressure.
    i had a very small leak from the bleed valve that i didnt know about until I had a full boilover one day.
    2005 vz ssz ute 5.7ltr 6spd/man
    Mar 2012
    lithgow
    Quote Originally Posted by Bulldog Edd View Post
    mate, ive got an 05 vz ssz and when i first bought it i did a coolant change, i had the same problem using the top up hole...... i was puring straight coolant onto the ground. pull your radiator cover off (you only need a flathead screwdriver and its about 5 of those pop head screws) its so much easier. just use the real radiator cap, its so much easier.
LinkBacks (?)
  1. 17-05-2012, 01:25 PM
  2. 17-05-2012, 01:21 PM
  3. 12-07-2011, 12:08 PM
  1. Vr Power Steering Reservoir
    By blocka1977 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2010, 09:59 AM
  2. brake fluid reservoir
    By dannyn12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2010, 01:45 PM
  3. VX L67 - Oil in Coolant & reservoir
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2009, 03:16 PM
  4. [VIC] WANTED - VR VS Radiator Overflow Reservoir Bottle must be brand new genuine (NOS).
    By The Harvester in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2009, 04:14 AM
  5. Power Steering Reservoir
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2005, 04:48 PM
