hey there,
i have a vz sv6 lsd diff and am wondering what size shims i should put in it to make it really tight (nearly locked) and can i buy these shims or do i need to buy shim material to make if so what material do i use?
cheers
you dont need shims- on VZ diffs you adjust the bearing carriers either side of the diff where the axles come out , you can really make them tight but it will destroy your diff bearings , buy a LSD diff instead......
