Results 1 to 22 of 22
Thread: vz sv6 dying!
    VZ SV6
    Jul 2008
    Thumbs down vz sv6 dying!
    i have no idea what is wrong with my car!!! please help
    when i plant my foot it seems my car just dies as its accelerating.
    its like its surging, or loosing power for a split second as i accelerate.
    VZ SENATOR
    Mar 2009
    How many ks has the car done?
    When was it last serviced?
    When was the last time you changed the plugs?
    Can you post a video of whats happening?
    VZ SV6
    Jul 2008
    wow lol
    serviced 5xxx ago.
    done 110xxx.
    plugs i have no idea.
    as for the video ill try post one but i donno if it will show whats happenin. cheers
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    fuel filter? spark plugs/leads? dirty air filter?
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Plugs are due to be changed at 120,000KM according to the book. I changed mine at 65,000.
    I would definitely get them chagned if you can't remember the last time they were...
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Sparkies, O2 Sensors, Fuel Filter, Leak between Throttle Body to Air Box (causes throttle to close at times due to loss of vaccume) or some other vaccume leak. Hell even a dirty air filter. Dirty maf....
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ SENATOR
    Mar 2009
    Change your plugs, if that doesnt help look at your coil packs on each plug.
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Is it just a miss when you boot it? And does it do the same when revving it in neutral? If so, it could be the spark plug delay. Probably time to change them.
    VZ SV6
    Jul 2008
    Best way for me to describe what is happening is.... when accelerating it feels like i would be tapping the clutch a few times a second. (even though its auto) lol
    I remember a while back the air filter came loose so ill check that again. but other than that the air filter is clean.
    fuel filter and oxygen sensor have already had to be replaced.
    It doesnt happen in neutral its only when its being worked...so its a bit harder to tell if its the motor or gearbox or diff. grrrrr
    how much is it to get the plugs done?
    whats a good brand to get. price doesnt really matter as there only spark plugs anyway. =]
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    6 Plugs usually cost around $70 from Holden.
    A good brand would be Bosch. When u get them make sure there platinum tipped. This type of engine requires these plugs
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    I got Bosch plugs from repco, platinum tipped at trade price was around $60, Slightly cheaper then what i was quoted from holden. I would definitely get them from holden unless you can get a discount elsewhere.
    VZ SV6
    Jul 2008
    hard to change yourself.
    or should i just go to a shop and how much would that be?
    also would this solve the problem of my car stalling sometimes.
    VZ SENATOR
    Mar 2009
    Read this thread - Engine hesitant in first gear
    I had a very similar problem to you that turned out to be the coils. The thread above should help you with some more info on changing your plugs and where to source cheap coils.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    coils? I didnt think these motors had them, correct me if im wrong but it was electronic ignition as in all done by the computer?
    Life starts at 200km/h
  15. #15
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    One ignition coil per spark plug = 6 coils.
    They plug directly onto the spark plug & bolt onto the engine to carry the weight & prevent movement.
    A genuine set costs an arm & leg from Holden, but you can pick up Bosch kit off Ebay for about 30% of the cost of genuine ones.
    Fitted a set today together with new plugs & front O2 sensors. Not a problem.
  16. #16
    vz commodore lumina
    Jan 2010
    sydney
    i have The EXACT problem with my 05 vz lumina, it just dosnt give when you floor it, its not the air filter nor spark plugs, its more so the gearbox and the ks on my car are 42000 i am unsure to get the gearbox changed or dont no what to do but i fell your pain
  17. #17
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Trent L View Post
    Excellent, now i know! Thanks mate..
  18. #18
    VZ SV6
    Jul 2008
    also yesterday my car stalled just on idle and it said change oil. although i checked the oil and it is clear as.
    any ideas on which oil to use?
  19. #19
    Dec 2009
    Penrith NSW
    Quote Originally Posted by impulsive View Post
    Not a prob impulsive. Feel free to take the p#ss ..... I hadn't read your total posts but appreciate the sense of humour.
  20. #20
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    lol not taking the piss mate, i honestly thought the alloytec was coil less, as there are no real Ignition lead to coil pack process.. similiar to my VR. Does this mean coils are Upgradable, assisting in more power and better detonation?
  21. #21
    Dec 2009
    Penrith NSW
    All I know is that a set of these worked for me.
    GENUINE HOLDEN COMMODORE VZ V6 BOSCH COILS 3.6L - eBay, Other, Car Parts, Accessories, Cars, Bikes, Boats. (end time 30-Jun-10 16:40:42 AEST)
    Got a set of plugs & O2 sensors from the same guy. Everything is working - so I'm happy.
  22. #22
    VZ SV6
    Jul 2008
    so whats the go?
    injectors? spark plugs? or coil packs?
    hopefully i don't want to have to replace the lot.
  1. Why is my car dying?
    By Da_Blak_Ravn in forum Electrical Wiring / Questions
    Last Post: 08-10-2008, 10:32 PM
  2. Help! My VN is dying
    By down_with_the_system in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 01:24 PM
  3. My Car Is Dying
    By outlaw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2007, 10:03 PM
  4. Dying VR?
    By pineforest in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 11:19 PM
  5. my VS is dying help
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 08:11 PM
