Results 1 to 6 of 6
Thread: Replace vz sv6 fan belt?
    sire01TMK's Avatar
    sire01TMK is offline GO HARD OR F#@K OFF!
    96 VS ACCLAIM / 84 VK SL 308
    Nov 2005
    DARWIN, NT
    Question Replace vz sv6 fan belt?
    How do I replace the serpentine belt on my vz sv6?
    RIP 05
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    pull it off and put the new one on??...use a ratchet in the tensioner...
    if its too hard getsomeone else to do it
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    sire01TMK's Avatar
    Nov 2005
    DARWIN, NT
    Um I know I have to pull it off and put the new 1 on but which is the tensioner pulley?
    RIP 05
    V6 VT series 2, V6 VZ Calais
    Aug 2009
    Smile
    Pull the top engine plastic covers off. Take the plastic air inlet tube off. Identify the tensioner pulley (see photo) and memorize the route of the serpentine belt around the pulleys. (sketch on paper).
    Grab a socket wrench or ratchet (1/2 " drive I think) and twist the spring loaded tensioner clockwise to loosen the belt. Take it off and put the new one on. Use masking tape of something to hold in position while you work it around the pulleys. I find it easy to start at the bottom crankshaft and work clockwise and anticlockwise finishing at the top. You need to pull on the tensioner to slip the last bit over the water pump pulley. It's always a good idea to check the idler pulley bearing and the tensioner bearing while the belt is off and replace if any doubts on their serviceability.
    Good luck,
    tRev.
    Attached Thumbnails Attached Thumbnails Replace vz sv6 fan belt?-sketch.jpg   Replace vz sv6 fan belt?-tensioner.jpg
    sire01TMK's Avatar
    Nov 2005
    DARWIN, NT
    Thanks Trevhead62 :-) much appreciated brus.
    RIP 05
  1. How many of you who replace their own Timing belt
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2010, 07:34 PM
  2. replace fan belt
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2008, 10:31 AM
  3. how to replace a vl commodore altenator belt
    By vl limited edition 2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-07-2008, 07:09 PM
  4. when to replace serp belt
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 05:21 PM
  5. How to replace VN dive belt tensioner unit?
    By goldvn05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-05-2006, 07:03 PM
