Results 1 to 4 of 4
Thread: VZ Running like Crap
    Scottie666's Avatar
    Scottie666 is offline Scottie
    Vt Acclaim, 1988 Vl Comm,2007 VE BERLINA
    Apr 2009
    Default VZ Running like Crap
    Hi Peoples,
    my mate has a VZ and just today it has started running on three or four cylinders, i am guessing plugs since he doesn't think they changed them when he had his last service done,
    any ideas
    Scottie
    VY Ex-cop
    Mar 2006
    codes??? could be anything, coil pack. doubt plugs is more than one cylinder missing.
    Scottie666's Avatar
    Apr 2009
    Quote Originally Posted by TheIceman View Post
    iceman, so how do we find codes, what do i need to do to do this?
    any help would be great
    cheers
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    in relation to codes, if theres no warnings on the dash saying something like, check powertrain or something...all you do, is have your car turned completely off, press the mode and set button at the same time and turn ur key to accessories...the dash should display from memory " GM part number (whatever the number is)"..i may be wrong...use the mode button to navigate through this menu, you will find useless stuff in there..and don't be afraid when ur whole dash lights up and everything is set to half way, this is just a check...im pretty sure the last thing is the trouble codes, if there's no codes it will come up with lots of 0's...otherwise there will be a code such as P0562 or something, if a code comes up, post it on here or email me at bodyboardlife93@hotmail.com and i'll let you know what the code means and possibly how to fix the code/fault
  1. VL was running like crap, now wont even start :(
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-09-2009, 11:50 PM
  2. VQ Statesman running crap when cold
    By choppsy in forum Tuning
    Last Post: 15-07-2009, 07:05 PM
  3. VP running crap when hitting 1700-2000rpm
    By b3h3m07h in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 01:11 AM
  4. filled up at BP now running crap
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2006, 01:52 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
