I have a VZ thunder ute which is constantly cooking brakes on track days. I cant afford the HSV Harrop/AP kits. Has anyone had experience adapting a Jap import 4 pot caliper to the commodore. These seem to be pretty cheap if I can find the right one.
youll never make it fit and meet adr's on a budget
How is changing caliper going to fix your problem?
What pads/fluid/rotors are you currently running?
There's no reason why your standard brakes can't stand up to heavy track work as is with the right component.
Is your problem pad fade (rock hard brake pedal and no brakes) or fluid fade (soft spongy pedal and no brakes)???
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
