Results 1 to 13 of 13
Thread: V6 Alloytec data using OBDII / Tech2 ?
    05 VZ Berlina
    Mar 2010
    Question V6 Alloytec data using OBDII / Tech2 ?
    Hi all, I have an Op-Com for the wife's Vectra problems, and I got one of these Chinese "ELM327" OBDII interfaces for my VZ (CAN OBDII protocol : ISO 15765-4 CAN (11 bit ID, 500 kbaud))
    About US$20 delivered in less than 2 weeks.
    Diagnostic Code Reader CAN-BUS Car interface OBD2: eBay Motors (item 150435278968 end time Jul-18-10 04:50:53 PDT)
    Just testing the free software that works ok and I'm looking at the data. One thing I see is the intake air temp is showing around 100F (38C). Is this usual? (Outside air is only about 19C).
    See data in .txt file (used wOBD log export) the column is the one that starts with 114.8.
    Attached Thumbnails Attached Thumbnails V6 Alloytec data using OBDII / Tech2 ?-elm327cable.jpg
    Attached Files Attached Files
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Im not 100% sure but i think it measures the airs temp once it is in the intake manifold which heats the air up. That is why Manifold insulators are meant to give more power ect.
    05 VZ Berlina
    Mar 2010
    That would make sense.
    Although I thought I saw somewhere that the IA temp sensor was with the MAF - I could be wrong?
    Mar 2009
    Quote Originally Posted by FnomnaVZ View Post
    Im not exactly sure hey. If it is being measured at the MAF then 38c does sound high.
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    im pretty sure intake temperatures can vary between 30 and 60 degrees going past the valves, could it be engine bay heat heating up the intake pipes, manifold heat, or heat from valves and internal parts...it's gunna vary untill you know where it's pickin up temperature from
    05 VZ Berlina
    Mar 2010
    Good point. I'll check the reading again in the morning when there's no chance of anything in there being warm.
    If it's still saying 35 deg, is there a procedure for testing the intake air temp sensor?
    Also, what range of voltages are the oxygen sensors meant to show when running closed loop?
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    smart idea fnomnavz, if it's still reading 38 degree heat on a 19 degree cold day with a cold engine, somethings wrong haha
    05 VZ Berlina
    Mar 2010
    Just did another session from cold, then started the car and idled until it had warmed up a bit.
    (See .txt for all temps)
    Outside temp 14C
    Coolant temp 51.8F = 11C
    Intake Air temp 64.4F = 17.8C
    So I guess they're close enough.
    What would be the symptoms of bad intake air temp sensor data? Roughness, jerky gear changes?
    05 VZ Berlina
    Mar 2010
    Attached chart and Excel of temps as it warms up.
    Attached Thumbnails Attached Thumbnails V6 Alloytec data using OBDII / Tech2 ?-chart-tempsvsrpm.jpg
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I always thought the IAT sensor was in the airbox?? Certainly was on the Ecotec.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    05 VZ Berlina
    Mar 2010
    I remember my VT was more like this
    http://www.installuniversity.com/lsx...r_locators.jpg
    3 wires for the MAF, 2 for the IAT
    But the Alloytec has just one plug with 5 wires, so I guess they're combined instead.
    VZ SV6 3.6 A5
    Dec 2005
    SEQ
    Hi FnomnaVZ
    I have been thinking about a diagnostic OBD device but never had the confidence to buy one of them, as the available information seemed very poor/scarce when related to the Alloytech 190 donk and the modifications done by Holden Australia.
    The unit you cross referenced to eBay, does it have data available for all the column headings in your data downloads?
    eg Fuel pressure, Manifold air Presure, vehicle speed, Ignition Advance etc?
    Does it deliver any trouble codes suited to the 190kw motor?
    Does it give any data about the other computers (eg. auto transmission etc.) which talk to the engine management system?
    Many thanks for your help
    05 VZ Berlina
    Mar 2010
    FIrstly, for $25 I think it's useful anyway.
    The one I have, using the wOBD software, has all that data, except for
    - Fuel Pressure(kPaG)
    - Manifold Air Pressure(psi)
    O2 sensor data there are 2 : "O2 Sensor 1-1 Voltage(v)" and "O2 Sensor 1-5 Voltage(v)"
    I'll have to check with the other software.
    I guess it gives all the trouble codes. Haven't had one yet.
    I haven't seen any data from other computer modules (auto, ABS etc) so I'd say no to that. It's not like the OpCom I have for the Vectra.
LinkBacks (?)
  1. Tech2
    By webwombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2010, 11:57 AM
  2. OBDII for '02 VX
    By myberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2006, 01:10 PM
  3. OBDII/ECU Plugs
    By michaelw in forum Parts And Other Items For Sale
    Last Post: 23-11-2005, 10:47 PM
  4. So....where to get the OBDII connector in Oz
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 12:20 PM
  5. where is the OBDII port on the VR
    By michaelw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2005, 06:22 PM
Tags for this Thread
