Results 1 to 14 of 14
Thread: vz overheating
    vz sv6
    Jun 2010
    Default vz overheating
    hey guys new to this i have a 2005 vz as i was driving todady the temp spiked to the red then droped just over half i rushed it off to the mechanic he said it could be a cracked head..... if the head was cracked wouldnt the oil be white or is that just if its blown help me please any ideas would be geatly appreciated
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Check fluid level.
    Check hoses for cracks/splits.
    Have radiator specialist pressure test cooling system.
    Check engine oil for level and or discolouration.
    Tech 2 test for any error codes - if any, respond/repair accordingly.
    VZS-Ute06
    Aug 2006
    Western Vic
    Yep as BenBoy says also if water gets in the oil it foams up
    I'd change the thermostat it might be sticking shut
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    BANNED
    Feb 2010
    05 VZ Berlina
    Mar 2010
    Also try bleeding air from the radiator bleed screw. Search for the procedure on here somewhere.
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    if you wanna bleed your radiator, take the big plastic shroud off the front of the engine bay..on the left at the top of the radiator, on the side facing towards the engine, there will be a little screw..white if i remember correctly, just have the engine running, undo that screw bit by bit untill a bit of coolant pisses out...wait a little while, do it again...feel the top and bottom radiator hoses, when they're gettting quite hot (meaning ur thermostat is fully opened), do the same again, and that should be it
    VR V8 BT1
    May 2006
    I would say it is either your thermostat or coolant lid. I would try replacing these and then see what happens. Even if it isnt the cause they are the cheapest options and will prob need replacing anyways.
    VZ SS
    Mar 2010
    Perth, WA
    My Car was overheating recently 2005 SS, took it to holden and they told me it was my radiator, so I replaced it.
    Car overheated 2 days later. took it back to holden and they said, nah its not your radiator its your thermostat.
    same day the car over heated. took it to a different emchanic at AUTOMASTERS and they told me it was quite evident it was my water pump.
    They quoted me shitloads for one to be installed ($850) and so did holden so I found one online for $177. brand new aftermarket. and got Ultratrutune to installit and bleed radiator again.
    THIS FIXED MY PROBLEM!!!!!
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    ****en hell, i can see why you chose ur name to be injured_otter...having holden **** you around always hurts...i woulda ripped right up holden and gotten my money back..
    VZ SS
    Mar 2010
    Perth, WA
    well i did get a 200$ parts voucher. but sucks cos I would never go there again. but I know there is more out there now.... lol
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    200 bux voucher is always good..if it doesn't expire, wait till you need something genuine and use it..if it expires, you can always buy brake pads or some other wear and tear item...maybe have a look through ur service book and see what needs replacing in future services..spark plugs etc
    vz ss
    Jul 2010
    Gisborne New Zealand
    Dont get caught out. I had a vz v6 exec wagon spiking the temp gauge into the red for 10 secs, then heading back down to half. We suspected the thermostat, so put an aftermarket tridon thermostat in the car. All was well, road tested fine. Gave it back to the customer and it overheated again. Got the car back. Removed radiator to have it checked. Clean as a whistle. Carried out cylinder leak down test, all ok. Checked fan operation, all working as should. monitored live data, found that the o2 sensors were not cycling as they should. Replaced both sensors. Still no good. In the end after countless hours of head scratching I removed the aftermarket thermostat and refitted housing without the thermostat. Bingo! Car was perfect. Ordered and fitted a genuine thermostat and has been perfect since.
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    my tafe teachers tought me to never buy an aftermarket radiator cap..they're a little more complicated then just a screw on lid, so i think everyone should stick with this advice..could cause alot more damage then you think
  1. VR Overheating
    By Skater_jj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 03:36 PM
  2. overheating..
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2010, 04:07 AM
  3. STILL overheating
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2008, 06:27 PM
  4. overheating
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 08:11 PM
  5. STILL overheating
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2006, 04:16 PM
