Results 1 to 12 of 12
Thread: Oils
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Default Oils
    ok, so im pretty confident i've got an open diff in my ute...if i put a 85w-140 oil in it, does it matter if it's a limited slip oil or not?...does anyone know if the nulon 75w-90 synthetic oil is any good for my 6 speed gearbox?
    cheers guys
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    85W-140 is fine for the diff, but you need to find out if its LSD or not as LSD have a 100ml additive that needs to go in as well (I believe part number 92145121 from Holden ... or its called Sturaco 7098). Also make sure the oil is Synthetic, for some reason official Holden paperwork says V6 engines with manual or 5 speed auto need synthetic diff oil. Doesn't hurt to chuck it in LSD or not, I've got synthetic in mine and its just a single pegger.
    Yes Nulon 75W-90 is fine for the 6 speed manual box
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    yea, all oil in my car is synthetic, im pretty sure it's a slippery diff, i mean like..it's the poverty pack ute, plus it will spin one wheel..more then the other if i drop a lil burnout on grass or something...i tried to jack the car up to see what ways the wheels turn to determine if its an lsd or not...seeing as though im not very well equipped, i was only using the scissor jacks that came with the car....i was jacking up the second side of the car, then my idiot mate thought he'd sit on the front of the car, then it just rolled on the jacks..so i couldn't be stuffed to rejack the car up again haha...what oil do you have in ur car torquative? (brand, viscosity etc) thanks champ
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Torquative's Avatar
    Jun 2005
    LSD's will have a tag hanging off the filler plug, although this is easily taken off and not put back on if the oils been drained before so its not the best way to tell. I'd be double checking based off the info on the diff, if your gonna do it might as well do it properly!
    I'll have a look at what oil the diff was, we used Nulon but we were also servicing 3 cars at the time, a VX wagon, VZ Calais LSD and VZ Acclaim non LSD. Obviously with mine being Auto the gearbox oil wont help ya!
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    yea i have the tag, it says something like, high performance use approved lubricant only, or something like that, no mention of an LSD...umm, the label on the diff doesn't tell me much, theres numbers that don't seem to mean anythign to mean..the only thing i understand is it's a 2.87:1 haha, just say it is a single pegger, would LS oil still be ok?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i use nulon 85 - 145 heavy duty stuff, mine however is a LSD, havnt had no problems been in there over 6 months now
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    I have a question so i may as well use this thread. Im getting some chattering while turning in my VZ SV6. I know Holden have that 100ml of additive but i read in another thread that the additive is included in the Penrite sin 80 diff oil, is this correct?
    Torquative's Avatar
    Jun 2005
    if you have a look at the diff again (sorry I should've mentioned this earlier) there are some BIG letters printed on the label.
    2.87:1 ratio will have either AZ, BB or BC.
    AZ and BB are NON LSD (AZ is non slip without ABS, and BB is non slip with ABS), BC is an LSD. This will ultimately confirm what diff you have
    Also I used the Nulon 85-140 Heavy Duty Synthetic LSD oil in mine, its in a gold bottle.
    Paul, I'd be checking with Penrite. The additive is to thicken the oil in LSD's, so they may have already got the oil viscosity right in that particular oil.
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    yea mine has BB on it...yea, the nulon 80w-140 in the gold bottle is the one i was looking at getting,..it is a limited slip oil though...i think, cant remember....is it ok to use this LS oil in a non LSD...i dont know the difference between the LSD and non LSD oils, all i know is that the oil needs an additive...thanks heaps guys...youve helped me alot...oh yea..ill probably end up getting the same nulon oil for my gearbox, but in 75w-90...cheers guys
    Torquative's Avatar
    Jun 2005
    okay then, so we know for sure yours is non LSD and you now know the ratio!
    Ive used that Nulon LSD stuff in my non LSD for the past 18 months, in that time its done a track day where it got thrashed in 38 degree temps all day. Its also done a skid pan day and had a couple of open runs, and done somewhere close to 40 000 kays. On that score so has the wagon and Calais that used the same oil, although the Wagons also done a dyno day and also has higher torque being sent to the diff due to supercharger, so between us we've all thrashed the diffs with that oil in. The LSD's use the same oil, except you need the additive to thicken it, but in your case you don't need to worry so yes, its fine.
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    sounds safe to use this oil then ...thanks heaps torquative, i owe you one
  1. Oils aint oils
    By CANYONERO in forum LSx Development and Modification
    Last Post: 27-03-2008, 11:24 PM
  2. Oils Aint Oils
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-12-2006, 10:40 AM
  3. oils aint oils
    By carlyboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 06:59 PM
  4. Oils 'aint Oils - or are they ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2006, 08:51 AM
  5. oils aint oils ? ? ? ?
    By desruction in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-06-2005, 02:45 PM
