Ok I'm dumb. After servicing my SS and forgeting how to get rid of the servicing reminder. I managed to some how get Service Very Soon up on the display. I remembered how to reset the servive reminder. That is now gone but I still keep getting the S V S up and there is nothing wrong any Ideas how to get rid of the S V S. Thanks Ian
I have gotten rid of the service reminder. It is the S V S that I cann't get rid of. but Thanks
the S V S stands for Service Vehicle Soon. sorry
Shoul dhave read it properly, well searching the forum goes a long way. Try this thred.
HELP How to clear "SERVICE VEHICLE SOON"
Below was posted by user "Calaber"
" You can't clear the SVS message with your dash buttons. The fault is often a dud oil pressure sender switch, located on the base of the oil filter. It requires a special socket to remove, costing around $18 from Repco, and the switch is about $120 and I think, only available from Holden. It is a very common fault with Alloytechs and this is probably the most likely cause of the error message. Replacing the switch (if it's faulty) will clear the message."
You might have a problem lol
Also post in the correct section ie. this should be in "VZ Holden Commodore (2006 - ?)" section. Your going to piss off some people.
Thanks agian for the info. I am new to this so I hope putting it in the wrong section is not an going to make me drive a ford.
ok guys it was the oil pressure switch. $150.00 for a new one and problem solved. It very common in the 5.7 eng. thanks for the help.
It's also common in the alloytec V6 as well $72.00 for the sensor at Holden cheaper than bursons they wanted $94...
