Results 1 to 9 of 9
Thread: Exhaust heat shield rattle
    2005 VZ Exec - 95 VS Executive
    Jan 2007
    Default Exhaust heat shield rattle
    Hi,
    I did a search and found a few similar topics but didnt want to revive old threads.
    My VZ is on super lows and as such my heat shields under the car have taken a bit of damage due to steep driveways and dodgy roads in my area, i was wondering can i just remove them without any bad side effects, the shield in question is under the car at the very end of the headers where the it meets the cat convertor. At low revs it rattles and vibrates realy bad and sounds like a shitbox.
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    heat shields just stop hot air rising into the engine don't they?..if the heat shields just keep engine bay temperatures cooler, then you might find ur intake pipe will get a bit warmer, so ur gunna get warmer air into the engine, rather then cooler, resulting in a minor performance loss...?
    VT
    Apr 2005
    QLD
    Take them off.
    If you have heat issues through the floor pan, you can buy adhesive backed heat tape. Put that on.
    BUT you should be right.
    Be careful though, your intake pipe may get hot.
    lol
    Jan 2007
    the only thing im worried about is my floor getting overly hot, i assume holden put the shields there for some perticular reason.
    i might try and take them off and straighten them first, drive it for a few days and see how it goes.
    99 VT Sedan
    Feb 2010
    Hi all
    I felt my air intake pipe after driving it gets realy hot
    Has anyone heard of aftermaket heat shields to stop this problem???
    Summer-Sickness's Avatar
    Summer-Sickness is offline 2005 VZ EXEC
    05 VZ Executive
    Jan 2007
    Rockingham, Perth
    ive heard of people using kevlar exhaust wrap...
    was gonna try this myself but never got around to it.
    REHAB IS FOR QUITTERS!
    MY 2005 VZ EXECUTIVE
    VZ Commodore Wagon and EH holden
    Sep 2010
    nowra
    I strongly recomend that you have the heat shields there, whether you replace them with new ones or leave old ones on because the cat converter gets VERY VERY hot. they are put there for a reason, and it could lead to your floor pan getting way to hot, with carpet sitting on it is never a good combination
    2005 VZ Commodore Executive
    Apr 2011
    Shepparton, VIC
    I asked my mechanic about it awhile ago, he worked for Holden for 20 years before starting his shop up... He said the common fix at Holden is to remove em..
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I agree, everything is always over engineered. I had mine removed because i got 2.5" put in, no noticeable increase in heat. And it wont affect your intake because its under the floor not the bonnet(If you are talking after the cats, if you mean the manifold heat shield, removing it will heat your engine bay, marginally).
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  1. Anyone know how to stop the Exhaust shield from rattling on startup?
    By thebulk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-06-2009, 11:15 PM
  2. Need help with exhaust shield rattling
    Last Post: 12-04-2009, 02:38 AM
  3. Exhaust heat shield vibrating
    By satos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-02-2008, 07:15 PM
  4. heat shield issue
    By VZCalZone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 12:09 AM
  5. exhaust heat sheilds
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2005, 09:57 PM
