want to lower my vz exuecitive ute. its got 19s on it. how low can i go without any dramas? (what springs are they) and camber kit? will i need one. if so how much?
thanks
when i had 19's i went kings superlows . fronts were fine, rears had to get the guards rolled
did you put shortned shocks in too?
nope, standard fe2 shocks
how much does cost to get it all done including parts?
for someone to supply and fit around $700 off the top of my head... wheel alignment needed
ohk thanks. then to roll gaurds is about 50 bucks a guard yeah?
so dont need to put shortned shocks in ya recon?
How much weight were you carrying in the back of your ute impusivesv6?
Lukeyyy, its roughly about $50 a guard depending where you go, some people do recommend shortened shocks but maybe just see how you go first.
ZOMBIE
how will i know if i need shortned shocksis there a reason to put them in?
i have a vz calais with 19s and ultra lows i have still got standard shocks and have not got my gaurds rolled. i have no problem with scrubing
