Results 1 to 3 of 3
Thread: Calais - Indicators sticking on when un/locking car remotely
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    Default Calais - Indicators sticking on when un/locking car remotely
    My Calais has recently sprung an issue whereby the left hand side indicators will sometimes stay on permanently after locking or unlocking the car remotely. I have done a bit of research and found the most common fault to be within the BCM. I just called my local Holden dealer and was quoted $600 for replacement of the BCM, which includes two new keys (as my current keys won't work with new BCM and apparently can't be programmed to it).
    I was then asked if the problem had actually been looked at and confirmed that it was in fact the BCM, I said no and asked what else might cause this problem. He said 95% of the time it is the BCM, but sometimes it can be an issue with the BCM talking to the ECU. He said I should check the terminals at the BCM and ECU and make sure all the connections are good...
    So, can anyone tell me exactly where I can find the ECU and BCM to be able to check the connections?
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Cheaper option may be to read this forum about having your BCM repaired. I think the guy is Doctor Bob from down in Victoria, so perhaps send him a PM.
    BCM failure
    Just a suggestion.
    JBDrifter's Avatar
    Oct 2006
    Quote Originally Posted by Trent L View Post
    BCM failure
    Just a suggestion.
    Thanks mate, I PM'd him early this week and still waiting for a reply.
    Last night I forgot to check if it had gone off when locking my car, and sure enough it hadn't. So I woke up to a dead battery this morning, hense I'm clutching at straws for a quick fix and hoping it might just be bad connection between the ECU and BCM. I just don't know wherre the ECU and BCM are located.
  1. VS Calais Sticking Fuel Gauge
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 07:39 PM
  2. boot too heavy to remotely open?
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 05:53 PM
  3. sticking lifter in VP Calais
    By burns#44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-11-2006, 03:52 PM
  4. indicators to go off with central locking
    By ben k in forum Electrical Wiring / Questions
    Last Post: 13-05-2006, 11:14 PM
  5. Indicators Don't Flash When Using Remote Locking
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2005, 09:23 PM
