Results 1 to 14 of 14
Thread: Weird belt sound when cold
    VZ SS
    Mar 2010
    Perth, WA
    Default Weird belt sound when cold
    Hey guys,
    When I start my car, I get this chichichichichichichichichichichi sound coming from under the hood.
    It use to only be when the car is cold but now its happening all the time.
    A mate told me it may have something to do with the AC belt?
    Whats your opinions?
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Chevrolet Lumina LS 2005
    Jun 2010
    hello bro,i also have the same problem, the sound gets louder when i rpm increases. its a kind of rattling sound !!
    VZ SS
    Mar 2010
    Perth, WA
    yeah it get faster as I put my foot down. I dessagree with devil_87 though. its not a rattle. it definatly sounds like a belt?
    V6 VT series 2, V6 VZ Calais
    Aug 2009
    More than likely its the serpentine belt telling you it may be time to change it out and/or one or more of the pulleys are a bit worn and could do with re-newing. If the belt looks good (no cracks or out of shape) you can quieten it down by rubbing a block of soap or wax onto both sides of the belt. But this generally only lasts a couple of days. I have heard of spraying RP7 or CRC on it to stop such noises but the mineral oils and solvents in this stuff will end up deteriorating the rubber compound of the belt quicker.
    If it's 'rattling', it could be the tensioner bearing or the idler bearing that's shot. Better get onto it sooner rather than later... it could seize or collapse then you aint goin' nowhere.
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    trevhead62..your right on the mark..that was precisely what i was going to say..i could only just get on the computer so sorry for the late reply..but yea, rubbing a block of soap can help..i had a chirp when i started up my ute everytime, only for a split second though..i rubbed a bit of soap on there, and it went away..but not for long..then i found out it's a normal/common thing to happen with these engines...but yea..what trevhead said is spot on...jsut check the condition of ur belt and pulleys, if there's any obvious damage, give us an update if ur unsure or get it looked at/fixed straight away...as trevhead said..things such as a tensioner or idler bearing might be better off getting fixed sooner rather then later...oh btw, if it is a idler bearing it only cost my dad 50 bux on his vy to get it replaced...tensioner is easy as so it shouldn't cost much either
    cheers mate
    VZ
    Feb 2006
    SE.MELBOURNE
    That kind of sound means not much oil ...check ur oil.... reason i say that is coz happen to me i checked the oil and was low so i added oil and voila...that sound went away in a minute.
    VR EXECUTIVE We had some good times
    VZ SS
    Mar 2010
    Perth, WA
    thanks for all the help guys, ended up spraying a little CRC onto the serpentine belt and the sound went away instantly. Got the belt changed now and the Car is back to normal.
    Geez I love the internet.
    thanks again
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Quote Originally Posted by torana355 View Post
    Would be the serpentine belt.
    It was the serpentine belt Einstein. OP's problem has been solved already.
    Mar 2009
    Quote Originally Posted by HoldenOnn View Post
    I didn't read the whole thread i just answered the question. How about minding your own business because last time i checked you were not a moderator.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I have 2 suggestions:
    1. Perhaps you should read a thread before posting, the post right above yours is the OP saying he's solved the issue.
    2. When you post something silly, there is a good chance you're going to be pulled up on it. HoldenOnn is not a moderator, but neither are you.
    Cheers,
    Mar 2009
    Quote Originally Posted by Jesterarts View Post
    Cheers,
    That's fine but i had a quick look at the question and answered it which i see no problem with and it definitely does not deserve a smartarse comment like HoldenOnn replied with
    I usually read entire threads btw this was a one off
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Haha fair enough. I've done that on occasion too, people feel an extra ruge to point out my mistakes in particular being a mod.
    And a bit of smartarse banter is to be expected, it's a commodore forum after all... lol
    Cheers mate,
  1. Coolant Leaking When Refilling Cold Car - Weird One
    By MayhemOfHell in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2009, 09:36 AM
  2. Weird Sound
    By Timoshii in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2008, 12:41 PM
  3. weird sound with vr
    By Insanesinner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2006, 07:19 PM
  4. intake sound weird?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2005, 08:05 PM
  5. Weird Sound
    By Joshy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2004, 10:35 AM
