If you take the manifold of the car do you have to replace the gasket or can you just buy some gasket glue??
Get a metal replacement one from holden, then you dont have to worry about replacing it again..
Life starts at 200km/h
do u know how much at all?
Around the $50 mark for a plenum gasket from Holden. They are actually for VE's but obviously fit the VZ.
thanks, wasnt sure, but was going to call in the morning.. i still have the paper gasket
i need one of these haha..took mine off before, seemed ok, but still needs replacing...hey guys, is it normal to have an oil like substance, if its not oil within ur plenum and in ur inlet manifold..i also had oil on the gasket itself :S
yeah that is normal, was explained to me once, i asked the same Q..
ok thats good then, so if i replace my paper gaskets with the metal ones, would i have to put abit of oil over the gasket or just take the old one off, stick the new one on and do nothing besides stick the plenum back on?
