Results 1 to 20 of 20
Thread: throttle body...?!
    MattMarkey is offline Matty
    05 VZ CALAIS
    Nov 2009
    Raymond Terrace & Newcastle, NSW
    Question throttle body...?!
    hey guys.
    wondering is there any aftermarket options for a bigger throttle body for the V6's..?
    with it being electronic and shit like that, would u still be able to get a bigger throttle body?
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    :S wow, good question, i haven't actually seen one around, just done a quick google and didn't find much info on it:S crazy
    05 VZ CALAIS
    Nov 2009
    yeah i've just been thinking about it aye...
    it would be good if there was something out there.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    none available that know off, and nothing can be done with the stock item...
    i have one here in pieces... lol
    unless you wanna get one off a fly-by wire v8, re wire the plug, and make an adaptor plate...
    05 VZ CALAIS
    Nov 2009
    ....nah i'll be right haha. i wanted something easy to do.
    unless it is easier then it sounds???
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    its easy? if you handy with soldering iron and making shit
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    05 VZ CALAIS
    Nov 2009
    05 VZ CALAIS
    Nov 2009
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    Quote Originally Posted by vn_v6 View Post
    couldn't have said it better myself hahaha
    05 VZ CALAIS
    Nov 2009
    well maybe i wont sweat it lol.
    i'm just thinking about smallish shit like that, that would make a difference to the car.
    also..... people say that the alloytecs don't go well being MAFless tuned... why exactly??????????????
    VP Exec
    Jun 2005
    It would be good to see more tuning parts for the Alloytec. A better flowing throttle body may be difficult because of the error correction in the DBW. There is a check made against the measured airflow and the throttle angle achieved (measured at the TB) vs road speed and engine speed so that if the airflow for a particular throttle position is more than is "possible" the DBW goes into a limp home mode. That would have to be considered if swapping in a higher flowing TB. Maybe the parameters in the PCM can be changed.
    A bigger TB would also affect the operation of cruise control and TC.
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    well decided spin the throttlebody i have to see what could be done, and turns out i was wrong...
    result after machining is a 74mm butterfly machined out from the stock 68mm...
    10% larger in area
    had to be very careful while machining... the front diameter of the tb is only 70mm... so its not 74mm all the way thru...
    tomorrow it will hopefully be completed ready for a test drive
    im expecting a little bit more response, maybe a little more boost... but also the gearbox to shift earlier..
    a 75mm throttlebody from the v8's are $220 i think from holden
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    will the v8 ones fit the sv6 without problems?
    Spoken by a true member of The Committee
  15. #15
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    Quote Originally Posted by richardpalinkas View Post
    nope...
    ive posted before "unless you wanna get one off a fly-by wire v8, re wire the plug, and make an adaptor plate... "
    then who knows what it will do with the stock tune...
  16. #16
    3.6L Alloytec V6
    Jul 2010
    Maryland
    Ive been trying to figure this out for a wile now.....Theres a company that uses the same motor as us (cadillac's and Commodore's)
    Cadillac CTS V6 Offroad Engine Package From MecTech Motorsports
    And these guys have a 75mm Cable driven throttle body on it
  17. #17
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    fitted the modified throttle body, but no good...
    car idle surges between 1000-3000rpm and after about 20 seconds throws a check powertrain....
    rang Matt Stocker the best alloytec tuner and the vcm software doesnt have the idle parameters available to tune... the v8's do but not the alloytec
    so thats the end of the line...
    before - 68mm
    after - 74mm
  18. #18
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    so shiny haha
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
  19. #19
    May 2009
    Gold Coast
    Quote Originally Posted by impulsesv6 View Post
    fitted the modified manifold, but no good...
    fitted the manifold or the throttle body? thought u had the manifold on already?
  20. #20
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    oops.. typed wrong... should have read
    "fitted the modified throttle body"
    edited the above post
  1. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  2. v8 throttle body
    By s65481 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-09-2009, 12:42 PM
  3. vt throttle body
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2007, 05:13 PM
  4. v8 throttle body
    By vnv88u in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 04:10 PM
  5. throttle body
    By mistermeena in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 12:49 AM
