Results 1 to 3 of 3
Thread: Fault code for vz calais!!!
    MattMarkey is offline Matty
    05 VZ CALAIS
    Nov 2009
    Raymond Terrace & Newcastle, NSW
    Exclamation Fault code for vz calais!!!
    hey guys..
    i have previously posted threads about my gearbox shitting itself.
    well... i have the codes that popped and it is.... P0741 TCC (torque convertor clutch) performance STUCK OFF.
    any ideas????????????
    V6 VT series 2, V6 VZ Calais
    Aug 2009
    Sounds like solenoid is knackered in your tranny. See below:
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    If the PCM detects high converter slip when the TCC is commanded on, then a DTC P0741 will set.
    The following conditions must exist for two times during the same ignition cycle.
    This code will set for all the same reasons that a P1870 will set:
    • The TCC duty cycle is greater than 50%
    • The TCC slip speed is greater than 180 RPM for 7 seconds
    • TCC slip in 3rd gear on 4L80-E transmissions
    Known causes for P0741:
    • Worn TCC valve bores in the valve body
    • Damaged or worn pump bearing seal
    • Defective TCC PWM or TCC apply solenoids
    • Restricted separator plate solenoid feed orifice
    • Defective converter
    • Computer reprogram
    • Channel plate sleeve & turbine shaft sealing
    ring damage
  1. VT Calais 99 - Fault Code 46 & 47 - car stalling
    By BrisbaneVTOwner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2009, 10:58 AM
  2. VT Calais 99 - Fault Code 46 & 47 - car stalling
    Last Post: 31-01-2009, 02:12 PM
  3. Fault Code 42
    By 89 vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2008, 06:05 PM
  4. Fault Code 81
    By Nanos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2008, 02:42 PM
  5. ECU Fault code
    By TigerVX in forum Electrical Wiring / Questions
    Last Post: 26-07-2005, 05:55 PM
