Results 1 to 8 of 8
Thread: VZ guard scraping
    VZ acclaim
    May 2010
    Default VZ guard scraping
    Hey, tried researching this abit but couldnt really answer what i need to know.
    I have a VZ acclaim, and have put some mtx 19inch rims on it, they are offset a little not sure exactly how much though,
    I really would like to drop it a little, to get the guards sitting just above the rubber ideally.
    I dont think guard rolling will do much as it looks like the point most likely to scrap would be the part were the wheel arch contacts the rear bar...
    has anyone lowered with similar circumstances that may be able to let me no how theirs went or if there is any options to avoid scraping??
    Cheers guys
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    VZ acclaim
    May 2010
    yeh im thinking that is the outcome, was told if i only lower it 20mm and put some airbags inside the coils itll be fine, prob going to cost around 800 to do this tho, is it worth it for only a 20mm drop?
    VZ acclaim
    May 2010
    Local panel beater told me he will be able to massage the guard out up to 20 mm,
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Spray painter told me to grind the inside of the guard lip as opposed to rolling the guards. I did it and it is slightly better, make sure that you do a clean job tho, don't want any metal shards slicing open the sidewall of your tyre.
    VZ acclaim
    May 2010
    Cheers for the tip, Spose that'd be easier before they rolled
    Rekon if I lifted it up and took springs out then just lift the wheel up into the guard that'd give me a good indication how much I need?
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    VZ acclaim
    May 2010
    Would if i had the cash, if it comes to that i will.
    but if i can get it to work with these that would probably be the cheapest option.
  1. T5 Gearbox Making Scraping Noise VS Ute
    By Gilly91 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 12:34 PM
  2. Window is Scraping - HELP!
    By Flat_White in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-10-2008, 10:21 AM
  3. vx ss loud scraping noise??
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:36 PM
  4. Front left wheel flush with guard, front right within guard. What's goin on?
    By Evman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-02-2007, 12:22 PM
  5. VN Steering Scraping Sound
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 09:52 PM
