Question for you impulsive, just rung Holden about the monaro cai, and he quoted me $450 which was the whole replacement for the bottom of the air intake box. So I don't know exactly what part I'm searching for. Care to shed some light?
There is a thread, has the part numbers and everything. Should only cost $35
Life starts at 200km/h
how does the 2 hole mod work exactly?
im getting a growler delivered this week hopefully, so ill let you guys know how the instilation goes n if any gains are present once installed
VZ SV6 now, Jelly?
oh n just for the record. my mechanic who told me to buy a growler tried the mace ones n got nothing from it other then a lil sound.
he dynoed his vz with the growler n got an extra 3rwkw's at higher rpm's, like 3000+.
hoping to see similar results with mine
and in regards to the 'which cats should i get' question, be aware that if u go too smaller CPSI u will throw fault codes at ur dash constantly, cause ur O2 sensors before n after the cats will have a field day with all the emmisions ur letting through.
iv been advised when i do this to my vz, to get aprox 200-300CPSI cats, as 100's will more than likely create dramas.
VZ SV6 now, Jelly?
growler is in. flat spot at 2200-3000 revs is gone now![]()
VZ SV6 now, Jelly?
HOLDEN VZ VE ALLOYTEC V6 3.6L 20% POWERBOND UNDERDRIVE BALANCER PULLEY BELT KIT | eBay
that the one you brought?
^been highly advised to not waste my 300$ on the underdrive pully system. 300$ from that went to growler, money well spent!
VZ SV6 now, Jelly?
I Used To Have a Open Mind But My Brains Kept Falling Out
Originally Posted by drewVHSS
If you wish to buy that, i have some sweat from the ball sack of an elderly yak, if you rub it on the rocker covers of your engine, it'll unleash 1-2 killerwasps of powah!.
The Placebo Effect
The placebo effect is the measurable, observable, or felt improvement in health or behavior not attributable to invasive treatment that has been administered.
I trialled one years ago when i first got my commodore. was not going to pay $300 for something that does the same job any standard airbox does.
took my headlight and growler out today n went for a spin round the block with just a free flowing maf. gosh the throttle response was so much better no lagg or anything. wish i could just leave the headlight out n have the growler sucking nice fresh air![]()
VZ SV6 now, Jelly?
I don't come on forums very much (they tend to annoy me) and rarely post at that, but good to see people are still playing with these things! Great thread you have going...
Anyway, I understand this thread is more focused on 'bang for buck' mods, but I thought i'd post up some recent developments which hopefully will highlight how much potential these things have...
This is on a 100% stock engine - we've added a turbo kit and fuel system to suit E85, currently we have seen 313rwkw on an initial tune, will continue tuning this week. There's a lot more room to move with this thing, and we anticipate 330-340rwkw, but only more time on the dyno will tell. No matter what happens I'm already happy with what we've got at the moment. Keep in mind this thing also has a 4000rpm converter... And again, this is all on a stock engine... Plan on running a number in very near future. This car has been drivable for quite some time and runs brilliantly, no significant issues to report through the entire build.
Point of this post is to highlight that these things are tough with a lot of potential, i hope you all keep tinkering to see what you can get out of them. There's a bit more info on the 'Show Your Ride' section, the link is in my sig block below if any of you are interested which has pictures/dyno printouts etc.
just wondering has anyone used auspac 2.25 twin exhaust?
i got qouted $500 with tips
apparently there the best for the alloytech
hey everyone heard from a friend that converting to bigger throttle body,bigger fuel pump and intake and what not can make a decent horse power change just checking in to see what you have to say cause i wasnt that sold...
The standard fuel pump is fine for Na, but needs upgrading with bigger mods such as forced induction or head work. Bigger intake does help, as in the cpr6, however, no larger throttle body is available yet
whats the cpr6 going for and is it a noticeable power increase ?
i want a quick take off is changing diff or getting a mini spool worth it ?
Changing the diff gears will make a massive difference, that being said you don't wanna go too high as it will affect highway driving (with your car revving higher and chewing more petrol). A mini spool is fun I had one in a vh with 3:9's, for everyday driving it got annoying as I was chewing up tires all the time cause one wheel skips around corners trying to keep up with the other all the time, more noticeable when you go slow. I'd look at a LSD and some higher gears but nothing silly. Maybe some others guys on here can recommend a good ratio.
Posted with my iPhone 4s through tapatalk
Yes, I wouldn't go spool unless a track car. LSD with 3.45 is a good combination for highway and quick acceleration. Just gears alone did knock off .2 sec down the 1/4, so an improvement.
Just wanted to ask how you got around the clearance issue with the mace insulators and CPR6 under the bonnet? Mines just touching it causing it the vibrate the bonnet resulting in a little unwanted rattle noise.
I'm forced to use the insulators because my gas injectors are in the way of where the CPR6 would usually sit.
So Iv modified the insulators to sit on the plenum around the gas injectors.
Does your bonnet have that heat proof / sound proof cloth material under it?
Thanks.
Dave.
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
Mods on my 190 WL Caprice to date;
SS induction growler intake,
Pacemaker Extractors.
Twin high flow metallic cats,
Twin 2 1/4 cat back exhaust,
CPR6 manifold,
Mace Insulators 12mm,
3.9 LSD Diff gears
20% underdrive pulley kit.
Drilled and slotted Front & Rear rotors.
I'm happy with every mod Iv done so far but the CPR6 being the best mod.
Im going to get a Dyno run soon and see what the results are but i just don't know where to get it done. Lol
Any recommendations in Melbourne?
I'm also looking at getting it tuned but don't really wana pay $1100 i rekon around $600 is reasonable.![]()
You can get a tune for 660 on the gold coast. Or hit up mace for a mail order, heard they are pretty good
cheapest ive found in Melbourne is DYNOMOTIVE in Bayswater.....they do the VZ retune with good results from what ive enquired about...... just need to save the cash $990 i was quoted that include software upgrade pre dyno and post dyno runs and labour in doing so....
As I've said previously, the tunes should be at least 150 cheaper now than 900, vz requires only 2 vcm credits instead of 4. Maybe mention it to the tuner
