Just wondering if the standard vz steering wheel cd/volume controls will fit my sv6 without an issue or do i need genuine sv6 controls?
CAR ,Y U NO FIX YOURSELF
edited coz I gave the wrong info ...
they are different, see the below posts ;P
Cheers and that makes it a lot easier....holden spare parts dept told me i needed sv6 only which are $45 more than normal.
ah wait a tick, I've led you down a wrong path - had a mental block earlier when I wrote the last post.
Okay there will be a difference because yours has the Active Select paddles as well, apparently theres' a difference, not too sure what tho, but its to mount up to the paddles from memory.
2 colours, then 2 different switches according to either paddles or no paddles.
Aaaah now i get it but i think i might have to find a 2nd hand one as these things just keep on busting buttons...thanks for the heads up and i will search for one now.
yeah the active select ones have an extra wire to plug in as they light up, unless yours is a manual in which case they wont and exec ones will be fine..
mine went on my old one and it cost me 100 to replace them, although i did do them myself
Chev badges are an instant fail
Can you fit the ones that light up to a steering wheel that doesn't have lit up buttons?
So say put them in an Executive?
you can, but they wont light up
