Results 1 to 5 of 5
Thread: VZ ute ecotec wont start?
    04VZ Ute
    Jul 2010
    Thumbs up VZ ute ecotec wont start?
    I have an V6 04 VZ Ute
    At least twice a week when starting it up it will have
    ABS warnings(but ABS works perfectly). there are no trouble codes for this on car.
    Once a week it wont start at all, it will crank but wont start. You turn the key to accessory and see the instrument pannel lite up and the speedo needle goes ape shit and bounces up and down, but this goes away after about 1 to 7 tries and starts up normally.
    It produces several DTC most of which are Voltage problems some high, some low. Should i get a new battry?
    I love the Ute but its turning out to be more like my old Datsun each day, does anyone have any advice?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    If you got a vz mate you will have the 3.6L Alloytec, have u given it a good serivce, oil, plugs leads, air filter and fuel filter? you should also be able to take it too a battery joint and they can test ur battery for ya mate
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    04VZ Ute
    Jul 2010
    I ruined my first thread, thanks for the correction it is an Alloytec, most of the ute has been recently serviced except for the battery and injectors within the last 6 months. Originally when i bought the car at auction it had powertain errors which servicing everything seemed to fix. Still shakes at idle though, took to holden and they said its normal
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by stevo1 View Post
    All good mate, just send a mod a message and ask them if they can fix the name for ya, im not too familar with the Alloytec but if everythings been serviced id take it to a good mechanic and get them check it out
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    sounds like a battery problem to me, try disconnecting the battery for a little while, this resets the computer.
    Life starts at 200km/h
LinkBacks (?)
  1. VS wont Start
    By Hey Jimi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 07:56 PM
  2. VP V8 Wont Start
    By E_ri_k in forum Electrical Wiring / Questions
    Last Post: 04-03-2009, 03:57 PM
  3. vn wont start
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2009, 06:56 PM
  4. Car wont start
    By pickletime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2008, 07:01 AM
  5. my vs wont start
    By Greekos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2008, 12:53 PM
Tags for this Thread
