Results 1 to 7 of 7
Thread: Handbrake Thump
    VZ
    Jun 2010
    Default Handbrake Thump
    Gidday,
    Today I filled up with fuel and the petrol station driveway had fuel/oil all around the bowser. My shoes picked up a coating of slippery oil/fuel mix. I had to brake after leaving the station and noticed my foot slipping on the brake peddle. So to avoid a rear/front ender I pulled on the handbrake and as the car slowed a little I felt and heard a rather large THUMP from the rear of the car. Does anyone know what that indicates and have I done some damage? The brakes work fine after changing shoes and cleaning brake peddle.
    VZ Acclaim Wagon 2005
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    hmm, when i adjusted my vz ute and my dads vy acclaims handbrake..the first test goes thump, im pretty sure it's reseating the shoes in the handbrake....other then that i have no idea...any symptoms since then..has the car been serviced and had the handbrake adjusted?
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    VZ Executive
    Mar 2010
    Blue Mountains
    The THUMP is the diff twisting on the arms and the uni joints taking the strain of the twist. When in drive the drive train turns and the diff twists down or up slightly depending on the way its gears go. Remember Newton's laws of motion? To every action there is always an equal and opposite reaction: or the forces of two bodies on each other are always equal and are directed in opposite. Rolling forward and pulling on the hand brake you are stopping the direction and placing the force in the diametric direction causing every thing to take the strain. "THUMP" After all it is the car’s handbrake (e-brake : emergency brake) as said in the US. And thats what you used it for, and it worked...... Paddock bashing is fun, and handbrake turns are fun too. If the car is working fine and stops the same as it did before without the thump every time.........all good
    VZ
    Jun 2010
    VZ Executive
    Mar 2010
    Blue Mountains
    2005vzute's Avatar
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    haahhah didn't finish year 9..even more reason to trust his word:P hahaa..it sounds logical though:P..who gives a shit..aslong as the park brake does it's job, who cares if it moans n groans ahaha
    Vz "Storm" Ute
    Jun 2010
    Townsville, QLD, Australia
    I noticed my ute at first also done this..after i fiddled around with the control buttons on the dash i turned off the traction control and the problem stopped
  1. VZ Thump from 2nd to 3rd gear
    By Chicka in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-03-2012, 05:27 PM
  2. knocking and thump in engine bay of my vt!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:12 AM
  3. Tranny thump
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2008, 11:12 AM
  4. speaker thump
    By peter65 in forum Car Audio
    Last Post: 07-01-2008, 10:00 PM
  5. 'Thump' when I start my VS
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2005, 05:32 PM
