Results 1 to 10 of 10
Thread: Sv6 active select
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Default Sv6 active select
    Hey just wondering if there is any way of fitting an auto shifter with the active select on the gear knob instead of on the steering wheel? Like in the ve?
    Spoken by a true member of The Committee
    May 2009
    Gold Coast
    04 VZ SV6 A5
    Feb 2010
    why on earth would you want to? on the wheel is way better than on the gear shifter
    Ryley's Avatar
    Ryley is offline VZSV6
    VZ SV6
    Jun 2010
    Two Rocks/WA
    May 2009
    Gold Coast
    Quote Originally Posted by Slipper View Post
    reason is because when turning the wheel and needing to change its a little bit awkward. and it would be cool to have both paddles and gear stick
    May 2009
    Gold Coast
    Quote Originally Posted by Ryley View Post
    Here's a tip, buy a manual :P
    i would, but the missus doesnt drive manual, so bummer
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    generally you change down gear before taking the corner and change up while straightning the car....
    Chev badges are an instant fail
    May 2009
    Gold Coast
    Quote Originally Posted by ashbox View Post
    generally yes that is true, but still, can the mod be done or not? like the M3's how they have paddles and gear?
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Any mod is possible, it just comes down to dollars. But I don't know why you'd want to do it in the first place. Cost vs benefit = FAIL.
    May 2009
    Gold Coast
    true, i just thought maybe there could have been an aftermarket setup that could do it, but oh well. Question = EPIC FAIL
  1. active select shift
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2010, 09:33 PM
  2. How's the Active Select?
    By PhantomSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2009, 07:17 AM
  3. active select auto issue with my sv6
    By mmrdb in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-01-2009, 09:36 PM
  4. Active Select acting up (i think)
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2007, 05:03 PM
  5. VZ Adventra Active Select
    By AWD_VZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-11-2005, 09:41 PM
