Wheres a good place in adelaide to get a rattling exhaust fix. when i ever im coming to a stop my exhaust vibrates against the chassis in the centre, its really annoying, but i really dont think ill be able to fix it myself.
cant help you with the advice of were to go in Adelaide. i will share with you that i had the same problem. is it a custom exhaust? all mine required was wedging a rubber stopper in between the muffler/exhaust tip and the chassis. this brought the whole exhaust away from the rear bumper and stopped it from vibrating. im sure you've tryed to locate where the vibrating is coming from but obviously a bit hard if it only happens when your coming to a stop. trial and error- give it a go.
i got the same issue kinda, my rear garnish seems to be whats vibrating and kinda embarrassing rolling through town slowing down or slowly taking off and it vibrates haha . . . any cheap fixes?
check all the rubber mounts to see if one is broken or missing.
A while back I had the same problem and traced it back to the heat shields.
I re - adjusted them by losing them and slightly re adjusting their fit and the vibration disappeared.
