Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: VZ Radio Buttons
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default VZ Radio Buttons
    I'm just about to have a go at fixing the broken radio button on the VZ steering wheel.
    Is there anything I should look out for other than disconnecting the battery? Any hints - advice would be great.
    and 3 Dangerous non ABS VN's
    Phyco's Avatar
    Phyco is offline Alloytec and Proud
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Pull out the SRS Fuse as you will need to disconnect the airbag.
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    88GreenVN's Avatar
    Jun 2006
    Cheers for that.
    Phyco's Avatar
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    Quote Originally Posted by 88GreenVN View Post
    Cheers for that.
    No worries, had to do it myself not long ago
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Have a look in "How-to's", Remove VY/VZ steering wheel.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by VYMAD View Post
    Searching the how to's - I'm on it
    sincy is offline Donating Member
    VY
    May 2009
    ACT
    88Green, can you please let us know how you stick the button back on.. mine fell off ages ago and it annoys the hell outta me and i really want it fixed..
    thanks very much..
    88GreenVN's Avatar
    Jun 2006
    All done. Thanks for the pointers - car is back together inside 20 mins - tools back in the shed.
    I used a second hand set of buttons from the wreckers. I flipped the horn/airback up (not disconnected) and undid the 2 screws. The buttons just pop out if you push up on the centre tag. Slot the replacement buttons on and put it back together.
    The buttons are not repairable on there own as such - you need to get replacements that are all together. The buttons flex on 1 side and snap all too easy.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    spot on! Me and Phreddy tried to work on an easy fix solution of sort of plasti-fixing them, but they only survived a few more weeks before breaking off again.
    To anyone who does do this repair, make sure your keys are out of the ignition as a reminder ...and that you plug the airbag back in properly before connecting the air bag. If not, you risk setting off the SRS alert which needs tech 2 to reset. Depending on how well you get along with your mechanic (or Holden) it could be costly to re-set, as they may want to charge you to diagnose the fault (even though it was you who caused it ...) to ensure the SRS system is 100% working before releasing the car.
    88GreenVN's Avatar
    Jun 2006
    Here is my first attempt ar fixing the radio buttons. A bit of cloth on the inside and outside and some super glue.
    I've been pressing the button all morning and still holding together - now to test it in the car.
    Attached Thumbnails Attached Thumbnails VZ Radio Buttons-vz_radio_buttons_1.jpg   VZ Radio Buttons-vz_radio_buttons_2.jpg
    Torquative's Avatar
    Jun 2005
    good luck with it, let us know how it goes with time. Hopefully it holds though, there needs to be something to fix rather then replace these damn things!
    FG XR6T Ute manual
    May 2007
    Brissy
    Took me a good hour to do mine on my old vz as i swear the airbag was welded into place, and then welded some more. went back easily tho
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    88GreenVN's Avatar
    Jun 2006
    Road test No 1. It's fitted to the car now.
    88GreenVN's Avatar
    Jun 2006
    1 week down and the button is still in place and working as it should. Any one in Adelaide that has some broken buttons and wants to get them fixed PM me.
    Next time I will use better cloth and not so much glue...
  15. #15
    Torquative's Avatar
    Jun 2005
    sounds good! I'll keep it in mind, I think my 2nd replacement buttons are about to go
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Torquative View Post
    My temp repair is still working a treat. So 2 months of action on a daily basis - all good still.
  17. #17
    88GreenVN's Avatar
    Jun 2006
    Quick update - button still going strong
  18. #18
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    I also had the same problem. Seems to be a common issue. I went another route. I rewelded the flex side using a soldering iron. Still going strong several months later.
  19. #19
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by ozzypole View Post
    It's very thin plastic - but it crossed my mind at the time to melt it but chickened out.
  20. #20
    05 VZ Berlina
    Mar 2010
    I did similar to yours. Mine was just the volume + button. I could pull out just the button without taking off the airbag.
    I used a bit of flexible plastic - like that used for packaging things you buy from the shops.
    Then I used selleys plastics glue to stick the strip onto the button - in the same place you put your strips.
    I then put a bit of glue on the strip before wiggling it through the gap and pushing it into position. Glue grabs in seconds and left it overnight.
    Works fine this morning.
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
  21. #21
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by FnomnaVZ View Post
    Good job on not removing the air bag
    I can report back also the button is still working fine and gets used every day.
  22. #22
    WL Caprice
    Mar 2011
    Even with thin plastics, a soldering iron and a staple can work wonders. Heat up one surface so the staple can slightly insert into the surface then do the same to the other piece. Give a drop or two of quality glue to strengthen the bond once cooled. Do this thing quite often with small camera components that become brittle and collapse or disintegrate. Lasts generally 1-2 years before total replacement needed.
  23. #23
    VZ
    Oct 2008
    my + button is loose and is held together using electrical tape, but was wondering how i would undo the same button from the car at the wreckers..can i pop them off with a flat blade screw driver or do i have to undo the air bag etc??
    can someone tell me a nice and easy way of doing it? also once i have this "new" button, will it just pop right in to my steering wheel or do i need to take the wheel apart as described above?
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by muneey View Post
    The sets of buttons are held in with 2 screws and the part that snaps just unclip from it. I just poped my horn pad (air bag) up and held it while I undid the 2 screws. Takes all of 5 mins to do if you have a set of buttons to replace the broken one with.
  25. #25
    88GreenVN's Avatar
    Jun 2006
    Update - it's been well over a year now and button still going strong - and it gets hammered every day by a radio station hunter (my better half)
    I can say that adding a small amount of cloth with super glue at each end works a treat. The cloth remains flexible in the middle - if you dont use too much glue and make it all solid
  1. fix Vu Key Buttons ??
    By brockytt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-08-2009, 11:43 AM
  2. Help on fixing peeling paint on radio buttons
    By akqrate in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2009, 08:05 PM
  3. Stuffed Buttons
    By vlv8vic in forum Site Feedback / Site Problems
    Last Post: 03-10-2008, 08:32 PM
  4. F/S VR-VS Radio Remote Buttons & Repair Kit
    By ScottB_33 in forum Parts And Other Items For Sale
    Last Post: 13-03-2006, 09:44 PM
  5. Remote Buttons for Radio on VTII Berlina
    By ScottB_33 in forum Electrical Wiring / Questions
    Last Post: 03-03-2006, 05:22 PM
