Results 1 to 8 of 8
Thread: Vz sv6 problems
    SV6
    Dec 2009
    Default Vz sv6 problems
    I have been haveing problems for the last four months where my car won't start every Thursday. The car turns over but won't start and when it's does runs rough and sometimes stalls. It's done it twice after refilling and the other times just when starting it in the morning. Took it to a mech. They could not find anything. And only code that come up was to do with the key coupling code. What ever that is. It has come up check power train once when it would not start for five mins turning the engine over. Again no code
    I have replace air and fuel filter. Cleaned MAf sensor. Spark plugs o2 sensors. Checked throttel body. Just wondering where to try next. Fuel pump. Imobilers maybe. ???
    VZ SV6
    Oct 2008
    Newcastle NSW
    2004 VZ SV6
    Mar 2010
    VZ sv6 2004
    Jun 2010
    Quote Originally Posted by Hotblack View Post
    I could never quite get the hang of Thursdays...
    "Auther Dent"
    awesome reference is awesome
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The car wants u to start ur weekends early!
    Seriously,
    Key coupling code is to do with you using one key then changing to another. Cause its a rolling code thats always changing, it will throw up an trouble code.
    if you've had check powertrain come up id be checking under the car & having a look at ur O2 sensors.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    SV6
    Dec 2009
    both 02 sensors have been reaplced at the front. Well oxygen sensors that is. is that the same thing?
    SV6
    Dec 2009
    prob just cause will fill it up most thursdays i think. maybe a heap of shit in the fuel tank
    SV6
    Dec 2009
    Just found this on Holden handy hints web page will give it ago and see what happens.
    MODEL: Commodore
    SERIES: VZ
    PROBLEM: Crank but no start
    POSSIBLE CAUSE:Possible loose connection at control relay circuit or a possible faulty relay
LinkBacks (?)
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  3. Vz sv6 problems help!!!!!!!
    By allanssv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-03-2009, 08:27 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. My VT problems
    By VtBerlina_3800 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2006, 06:02 PM
