Results 1 to 5 of 5
Thread: SPORTS RYDERS, rear and front height totally out.
    VZ SV6 155.1RWKW
    Jun 2010
    Angry SPORTS RYDERS, rear and front height totally out.
    Hey everyone,
    I just had my vz sv6 lowered with pedders sports ryders springs and the front hasn't dropped at all while the back has dropped 35 mm... the shocks and strutts are still the stock fe2... help?
    Part no's
    2151R - Front
    2151L - Front
    2643 - Rears
    I've checked the part numbers over and over and i am 100% sure they are the "LOW" sports ryder spring. Any thoughts?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If they are anything like Kings springs then theres stuff all difference going from FE2 to lows.
    Silver Certified.
    VZ SV6 155.1RWKW
    Jun 2010
    just checked them again after the car has sat for a while,,,
    the front is exactly the same as stock height -- 600mm from the outer rim to the guard
    the rear has dropped about 30 mm -- 575 from the outer rim to the guard
    * 17inch rims
    i think pedders have labelled the front springs wrong giving me stock fronts and lowered rears...
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    If you had FE2 to begin with that is classified as lowered by Holden, so when you buy lowered springs from a suspension place their lowered are low compared to stock height Holden susp not FE2.
    Did you specify how low you wanted (in mm) or did you ask for pedders lowered springs because it sounds like you needed to ask for super lows.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VZ SV6 155.1RWKW
    Jun 2010
    Going from the pedders gallery this is how my car should be sitting with the springs parts i put in....
    Holden Commodore VY Sandman Panelvan - Pedders Suspension
    Holden Commodore VZ Ute - Pedders Suspension
    Holden Commodore VY Sedan - Pedders Suspension
    Instead of being 580mm at the front and 585mm in the rear like in the photos mine are 600mm in the front and 570mm in the rear.
    I rang pedders up today and could not get a straight answer why. The guy said with FE2 suspension the sports ryders will drop it roughly 15mm all round.
  1. Adjusting the height of the rear of the boot lid
    By rancid_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 01:13 PM
  2. SSL back - SL front height on 17" wheels.
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2009, 02:40 PM
  3. VK - Front Suspension Height?
    By philbio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-05-2008, 10:47 PM
  4. Lower front-rear same height?
    By akust0m in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2008, 12:27 PM
  5. Front height measurements differ
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2006, 12:27 PM
