Results 1 to 6 of 6
Thread: Calais auto headlights
    05 VZ Calais 3.6
    Aug 2010
    koo wee rup
    Default Calais auto headlights
    G'day all
    just wondering if anyone knows how to adjust the time the headlights stay on after you lock your car ? ive checked through all the settings and theres no option there to set it, only things like digital speed, calibration etc....
    could someone please help me ?
    Adz
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    There is an option that can change the time, its in the menu that comes up before you start your car.
    I don't have my manual in front of me but you need to activate the menu function before you start the car then go through each feature until you find the one you are after.
    Mine are set for 30sec unless i open the door then they turn off.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    As Surfwagon said. ^^ Turn the ignition to on as usual, wait until the "Holden System Check: OK!" disappears, and then it displays the option for entering the customisation menu by pressing up or down. First two screens have instructions, then after that it cycles through the options you can set.
    FYI, the option you are looking for (can't think of the name at this stage) applies only when the ignition is turned off. Someone correct me if I'm wrong, but the automatic light control timer starts from when the ignition is switched off, not when the car is locked. Hope this helps you out a bit.
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Have the manual in front of me now and the section you are looking for is "headlights off delay time" adjustable from 0-180seconds I believe from when the ignition is turned off and door opened, pages 1-27 & 1-35 in the manual.
    05 VZ Calais 3.6
    Aug 2010
    koo wee rup
    05 VZ Berlina
    Mar 2010
    Have you had the standard stereo replaced with a different one? I read somewhere that can stuff up the options you have available.
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
  1. VX Auto Headlights
    By ruggj in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2010, 08:16 PM
  2. Auto Headlights
    By ducatis in forum Electrical Wiring / Questions
    Last Post: 26-02-2010, 09:40 PM
  3. VT calais "auto" headlights not functioning properly
    By muneey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2008, 04:16 PM
  4. Auto headlights
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-01-2006, 12:32 PM
