You don really have to remove anything to get them out, you just have to manoeuvre your hand around a bit.
All you need to do is reach behind the headlight until you feel a little plastic tab behind where the parker sits, you then twist it and the whole thing comes out.
Then you pull out the old globe, put the new one in and refit. Quite easy once you have found the tab.
LinkBack URL
About LinkBacks
