+ Reply to Thread
Results 1 to 6 of 6
Thread: Scrape noise from engine
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride VzVzVz Executive
    VZ S ute
    Jun 2009
    Port Melbourne
    Default Scrape noise from engine
    I noticed about a month ago that my engine made this strange scraping noise when under throttle comming up to 3000rpm. I can only hear it breifly, but it doesnt sound good. When I accellerate up to 3000rpm in 2nd gear, it makes a 'shhhh' noise. It also does it when passing 2000rpm in a higher gear.
    Any ideas on where to start looking?
    VZ SV6
    Jul 2010
    Mandurah
    check you oils your big end bearing may be rubbing but i might be rong
    IF YOU WANNA REV IT CHEV IT
    nathanVS's Avatar
    nathanVS is offline the calais is sold nathanVS Calais
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    check your pulleys. mine used to do that, then it quietned down and got worse now it does it all the time lol, both idler pulleys need replacing on mine.
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Quote Originally Posted by nathanVS View Post
    Cool, I had a good listen under the bonnet at idle. It sounded like a pulley bearing shitting its self. I'll look into it.
    VR Calais
    Jul 2009
    Also check engine mounts sometimes when they get worn they make grinding/rattling noises under throttle lol
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    But what stumps me is the fact its only there at just under 3,000rpm and sometimes 2,000. I'm really hoping its not something to do with the variable valve timing.
+ Reply to Thread
  1. vn s1 engine noise
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2010, 12:52 AM
  2. Will they scrape...
    By 1991_Vn2nV in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2006, 03:38 PM
  3. engine noise!!!!
    By [SIK-GMH] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 05:01 PM
  4. wheel scrape inside arch... do I have problems?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2005, 09:07 PM
  5. Scrape
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-04-2004, 04:19 PM
