Hi All,
Hoping someone can help. I need to be able to remove the rear eye level stop lights from my Adventra (see pic). They have stopped working and I want to investigate the problem (although I am not off to a good start). Before I start hacking away at it, I thought someone might know how to remove it the correct way.
Cheers for any help.
Pete
Well a start would be to remove the plastics around the inside of the window starting on the bottom section. From memory there's a screw either side of the bottom section and the rest are just clip locks that take a bit to remove, like most of us take it slow.. Then test the loom before you start removing.
Cheers,
Dave
