+ Reply to Thread
Results 1 to 13 of 13
Thread: where do your VZ temp needles usually sit?
    2005 VZ Commodore SV6
    Mar 2010
    Default where do your VZ temp needles usually sit?
    hey guys,
    I'm just wondering where the temp gauge needle should sit once warmed up, this is mine after idling for about 20 minutes but where ive marked it is where it varies while driving, how about yours?
    mines a 2005 SV6 and ive also done the two hole mod if that matters.
    Attached Thumbnails Attached Thumbnails where do your VZ temp needles usually sit?-img_0724.jpg
    04 VZ SV6 A5
    Feb 2010
    yeah mate, 04 sv6 with 2 hole here and mines about the same once warmed up
    vz acclaim
    Jun 2006
    my car is the same as that i would of thought once it warms up it would stay in 1 spot but it dont it goes up when sitting in traffic and comes back down to the line once moving again
    TEAM CLOWN RACING
    Ando227's Avatar
    Ando227 is offline Serious? Ando227 Executive
    Vy Series II Ute
    Nov 2008
    Lightning Ridge
    BANNED
    Feb 2010
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja Little Red VZ Go-Kart Executive
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Moves to normal warm (white mark up from bottom) after 7 minutes driving and never goes above that, even after 4 hours on the freeway or in bog-slow city traffic. It's not summer yet, and I'm not a inchy-bitchy-slow-and-clinchy driver at any time, but techie said "it [engine] knows how to keep cool!", patting the kitty on top of the engine fondly. I've previously noted the two fans and thought one was a transmission oil cooler, the other being the radiator cooler, but apparently from reading posts one is linked to Air-con.
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride VzVzVz Executive
    VZ S ute
    Jun 2009
    Port Melbourne
    [Linkin Park]'s Avatar
    [Linkin Park] is offline From The inside [Linkin Park] Executive
    2004 VZ Executive 175kw
    Jul 2008
    Lawson, Blue Mountains, NSW
    Just a tad above a quarter. No matter of outside temp or drive style or even idle. But before i did a coolant flush around half. I use Nulon Concentrate
    2004 / Holden / VZ Commodore Executive / Automatic 4 Speed / 3.08:1
    ET (15.382) @ (89.52) mph / 2.281 (60ft)
    K&N Panel Air Filter, 2nd Hole Mod, Rear Muffler Replaced with Straight Pipe, Top Front Strut Brace
    http://img89.imageshack.us/img89/935/20102010026.jpg
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Quote Originally Posted by Ando227 View Post
    mine sits in the same spot
    Then your gauge is not too accurate, the temp is supposed to rise when in traffic until the thermo kicks in. My gauge accurately shows that the temp rises slightly when in traffic or when i give the car a very hard time. It moves between the same spots as the OP's pic.
    You can check out your real coolant temp by holding down the mode button when starting the car then scroll though to the coolant temp screen.
    Mar 2009
    Quote Originally Posted by slidways View Post
    Perfectly normal mate. The gauges holden use are not all that accurate so some of them don't move even though the temp of the engine has gone up 10 degress lol.
    Mar 2010
    Quote Originally Posted by torana355 View Post
    what coolant temp are you guys getting on average?
    Mar 2009
    Quote Originally Posted by xGR View Post
    It ranges from 90c to 110c usually. It sits in the mid/low 90's when moving along on and rises up to 110 when in traffic.
    Mar 2010
    Thanks for the reply torana, mines pretty much the same...90-110.
    Thought it was abit high but i guess its normal
+ Reply to Thread
  1. Morphing Needles
    By iinsom in forum ASR Audio & Electronics
    Last Post: 09-06-2010, 09:40 AM
  2. how to remove needles???
    By B_unit in forum General
    Last Post: 15-09-2009, 07:48 PM
  3. Different lights for my needles
    By B_unit in forum Electrical Wiring / Questions
    Last Post: 01-09-2009, 10:05 PM
  4. Painting needles
    By Snotty in forum General
    Last Post: 08-07-2006, 12:50 PM
  5. Help! Recalibrate Needles
    By paradox1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2004, 11:37 PM
