+ Reply to Thread
Results 1 to 10 of 10
Thread: Clunking noise when steering
    V6 VT series 2, V6 VZ Calais
    Aug 2009
    Default Clunking noise when steering
    Hi there folks, any body have an idea what could be the matter with my front end? I am hearing a clunking noise when steering sharply left or right as in when maneuvering in a carpark. The noise seems to be coming from the front left hand side. It's an 06 Calais, done 108K kms.
    Cheers, tRev.
    vz sv6
    Nov 2009
    vz equipe 3.6
    Sep 2007
    gold coast
    i have a feeling its your tie rod ends theyre a bush that connects your steering rack to your hub happened to my vs cost $110 fitted but you will need a wheel alignment too
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check your stabilizer link pin bushes.
    http://www.facebook.com/?ref=home#!/...21292461287296
    Aug 2009
    Thanks guys, I'm thinking stabilizer links too. Damn. I'll have to jack it up and have a lôôk.
    vzv6
    Aug 2010
    qld
    I had the same problem.
    Just check for rocks in where your front springs sit in the struts.
    VZ SV6 but have owned VC,VK,VL,VP,VT
    Sep 2009
    South East Queensland
    nathanVS's Avatar
    nathanVS is offline the calais is sold nathanVS Calais
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    wetwork65's Avatar
    wetwork65 is offline A wet business wetwork65 Executive
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Steering rack worn out? Cheaper to check the rack hold down bolts first for tightness - should be as tight as......
    VZ Calais
    Aug 2008
    Hi mate,
    Definitely your sway bay links - had to change mine recently as the bushes had finally given up the ghost (I've done 130k on the odo).
    While I was at it, I also did the strut bushes too - they had collapsed.
    Now the front end is tight as!
+ Reply to Thread
  1. VT clunking noise
    By VT_2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 04:29 PM
  2. Clunking noise
    By Michael_123 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-11-2009, 03:55 PM
  3. Clunking noise
    By [wcjb] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2009, 03:35 AM
  4. clunking noise lhf???
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 11:17 AM
  5. Clunking noise from steering
    By porkkhunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2006, 06:01 AM
