+ Reply to Thread
Results 1 to 16 of 16
Thread: diff oil????????
    MattMarkey is offline Matty MattMarkey Executive
    05 VZ CALAIS
    Nov 2009
    Raymond Terrace & Newcastle, NSW
    Question diff oil????????
    hey guys.
    wondering wats the best diff oil to use for my car.
    vz calais, V6 alloytec190. its not a LSD but i know u can use LSD oil in it.
    wats the best to use???????
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    If it not an LS diff why do you need to change the oil.
    There would be no advantage to changing it in a std centre diff, it won't save you fuel or wear and the diff will still last an awfully long time with the original oil in it.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    05 VZ CALAIS
    Nov 2009
    05 VZ CALAIS
    Nov 2009
    VZ Calais
    Jul 2009
    vz sv6
    May 2010
    yeap thats the stuff ya want got mine done at 125000km lucky i did slight shavings in it but changing ya oil every 5000km is good to do if ya can afford it thats what they have to do to the cop cars
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast MR_VX Executive
    VX SII Raptorcharged
    Mar 2009
    Townsville, North Qld
    Quote Originally Posted by jjbird85 View Post
    every 5000km would be the motor not the diff
    Check out my ride here =>My VX Raptor
    say NO to chev badges
    WTB - VY Black handbrake cover - Twin 2.25in exhaust to suit vx - vx/vy calais window surround chrome
    VYMAD's Avatar
    VYMAD is offline SILVERFOX VYMAD Calais
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yeah diff oil only needs doing around 80-100,000 k's. And yes it IS worthwhile doing.
    2005vzute's Avatar
    2005vzute is offline Djabringyagrogalong 2005vzute Executive
    2005 VZ Ute M6
    May 2010
    Glenfield 2167
    for my diff i used the nulon stuff...80-140 i think..its in the gold bottle, its about 30 bux a litre
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Bored or just wanna talk about cars? Add me on facebook and we can talk
    http://www.facebook.com/#!/profile.php?id=1002697869
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride VzVzVz Executive
    VZ S ute
    Jun 2009
    Port Melbourne
    I just bought a Castrol LSD diff oil from Supercheap that says it won't need the additive for the LSD. Is this true? Or should I still put in the additive?
    eaton v8's Avatar
    eaton v8 is offline my little sleeper eaton v8 Executive
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    the bloke from harts told me to use penrite 140 lsd oil he swears by it
    Experience is a hard teacher. First you get the test, then you get the lesson.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory HoldenOnn Executive
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Quote Originally Posted by VzVzVz View Post
    That is true. The Castrol SAF-XA already has the additive added in the oil required for LSD's. Don't add extra. Mobil equivalent on the other hand needs additive added if you have LSD. I believe the additive is called Sturaco 7098.
    Link below;
    CASTROL SAF-XA;
    http://www.tds.castrol.com.au/pdf/61...a_b1769_04.pdf
    VZ SS COMMODORE
    Aug 2010
    QLD
    Cant go wrong with Castrol SAF mate. Never had a problem with it
    Currently wrecking:
    - L67 VT Calais (all leather options / chrome) VT HSV MANTA 5.0L roller motor, L67 VT International II, V6 VX S-Pac II, VS SS II, VS Calais II, VT Wagon.
    PM me if you are chasing anything
    05 VZ CALAIS
    Nov 2009
  15. #15
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    I can understand some confusion concerning correct lubricants used in VZ differentials.
    The first attachment from the VZ manual states that using synthetic lubricant in a non LSD 3.08 ratio differential may cause seal deterioration and lubricant leakage. The next attachment 2 pages later has a note that then recommends to use synthetic lubricant in a non LSD 3.08 ratio differential, when extended heavy towing or towing between 1600 - 2100kgs over 80km/h is carried out.
    No wonder people are not sure what lubricants to use, when even Holden has contrary information.
    Attached Thumbnails Attached Thumbnails diff oil????????-vz-differential-lubrication-warning.jpg   diff oil????????-vz-differential-recommended-lubricant.jpg
  16. #16
    VZ Calais
    Jul 2009
    I dropped the old diff oil in my calais today and I'm glad I did... It was so incredibly filthy and gross - it actually looked and smelt like a sloppy shit... The car's done 135000km and did some towing and dirt road driving previous to me getting it.
    So yeah, I recommend changing it a little more regularly than never... maybe every 75000km (the car actually feels a little smoother now too, and the slight clunk that was present is now gone)
+ Reply to Thread
  1. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 12:23 AM
  2. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 01:19 PM
  3. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  4. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 08:51 AM
