+ Reply to Thread
Results 1 to 14 of 14
Thread: Correct Oil
    mdmatt is offline mdmatt mdmatt Executive
    2005 LS1 Auto VZ SSZ 328.6rwhp
    Aug 2009
    Default Correct Oil
    Just wondering, when you get your car serviced at holden what oil do they use? (For a VZ SS LS1 auto) and how much oil does it take?
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    10W/30 is the recommended weight and sump capacity is 6 litres I believe. I use 10W/40.
    dijm8's Avatar
    dijm8 is online now What You Looking At dijm8 Berlina
    VZ SS LS3
    Jun 2006
    Aug 2009
    cheers - as i don't have the service manual im after a correct figure for how much oil it takes?
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Aug 2009
    Oct 2006
    Bogan enclave
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I think you'll find they take 6 litres, I use 10/40 full synthetic and buy it in 6 litre containers and put the whole 6 litres in every 7500klms.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Aug 2009
    I bought mobil 1 5w-30 5 litres n changing the oil today.. this could be interesting.. might need another litre ;p
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R RiCeY Statesman
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    5.7-6.0 depending on how long you let it drain for.
    Quote Originally Posted by moggy
    That was pretty gentle and loving. Assault my arse.
    Torquative's Avatar
    Torquative is offline go in Luxury Torquative Caprice
    5.7 Barge and Cross 6 Adventra
    Jun 2005
    From the Holden workshop manual
    GEN III V8
    Engine oil viscosity and quantity specifications:
    Viscosity ............ GF3 5W-30 SJ or GF3 10W-30SJ
    Capacity without oil filter change
    Except AWD ........ 5.7 litres
    AWD ....... 7.6 litres
    Capacity with oil filter change
    Except AWD ....... 6.2 litres
    AWD .......8.0 litres
    But in all honesty theres a few variables, as ricey said depends on how long you let it drain for for instance. Best way is to fill it, let it sit for a couple of minutes to allow the fresh oil to drain to the sump and check the dipstick. If it needs a top up, top it up!
    Aug 2009
    Yeah cheers guys, it took just over 5 litres without the oil filter (couldn't get it off at the time n didn't have a tool) i'll just check it every now and then i've got the other litre i'll just top it up with that if needed.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I always change my filter(Holden or Ryco) so the 6 litre container is perfect as its only 200ml short of a full change over (by the manual) but I find it is always near perfect level on the dip stick after the change.
    BTW if you don't have a filter removal tool and you are replacing it just punch a screwdriver through the body (your throwing it away anyway) and and use the csrewdriver like a handle to turn it.
    Punch the screwdriver in as far clockwise around (looking at the head of the filter) on the filter to give you max turn anticlockwise to break the seal.
    Once you have done that the filter should just spin by hand.
    Also have your drain tray under the filter whislt doing this.
    Aug 2009
    Yeah cheers for that info ^^
    after changing the oil it sat at just above the correct level on the dipstick so all is good.
+ Reply to Thread
  1. 1 KW = 1.3 HP... correct???
    By walesy in forum The Pub
    Last Post: 15-01-2007, 08:16 PM
  2. Correct cable?
    By desruction in forum Car Audio
    Last Post: 04-01-2006, 06:09 PM
  3. Politically Correct....
    By rattattack1313 in forum Jokes/Humour
    Last Post: 01-08-2005, 11:12 PM
  4. am i correct
    By VNCommo in forum Car Audio
    Last Post: 31-07-2005, 02:17 PM
  5. Is this Correct ?
    By Darkwander in forum Car Audio
    Last Post: 13-02-2005, 09:41 PM
