+ Reply to Thread
Results 1 to 2 of 2
Thread: VZ V6 clutch
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride VzVzVz Executive
    VZ S ute
    Jun 2009
    Port Melbourne
    Default VZ V6 clutch
    I need my clutch replaced, just talking to my apprentice friend, he says the job is too much of a mind f**k to tackle by myself. What are your thoughts/oppinions on this? Has anyone done a VZ clutch without a hoist or fancy workshop equipment?
    Also, does anyone know of a good place to get a cheap exedy heavy duty clutch? I'm not exactly made of green.
    VZ AWD One Tonner
    Jul 2006
    You're in a bit of a pickle cause your car has s dual mass flywheel (DMF), which don't allow a heavy duty clutch to be fitted, unless you replace the flywheel with a rigid one. A standard, OEM replacement DMF clutch from Exedy is about $919.
    If you want to replace the DMF with a single mass flywheel (SMF), then your options (including the flywheel) are the following:
    - Exedy Standard clutch $1629 for the complete kit
    - Exedy Heavy duty clutch $1735 for the complete kit
    Clutch installation isn't rocket science, but it is very easy to stuff it up, and wreck the clutch. If it were a $200 clutch I'd say give it a crack, but I wouldn't say give it a crack when your clutches are worth as much as they are.
    Any questions feel free to give us a bell!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
+ Reply to Thread
  1. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 10:22 PM
  2. vr v6 clutch
    By ital355stroker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2009, 02:45 PM
  3. In need of a new clutch
    By trashthumpy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2008, 07:10 AM
  4. VR Clutch
    By BlackCougar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2007, 06:08 PM
  5. clutch
    By MY 5.0L VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 07:22 PM
