+ Reply to Thread
Results 1 to 8 of 8
Thread: vz calais headlamp globes
    9/04 VZ Calais
    Jul 2009
    broadford
    Default vz calais headlamp globes
    im sorry if this has been asked before....but
    ive blown a couple of H11 low beam globes on the calais and at $50-60 each im getting annoyed
    any suggestions would be appreciated
    ie can i put HID inplace of the H11?
    will that solve the issue
    i understand there is some grey area about the legality
    cheers
    Rob
    VZ Calais
    Jul 2009
    They're not legal cos we don't have headlight washers and they're not auto-levelling... But you can get them and they do work nicely
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh Troy711 W427 Troy711 W427 Troy711 W427 Troy711 W427 Troy711 W427
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    HIDs will go straight in, all you need to do is drill a hole in the dust cap on the back of the light to run the extra wires. I've got HIDs in my car and they are awesome. To be totally honest, the only time you really have issues with HIDs being too bright is when idiots fit them to lights without a projector lens. If you go ahead with them just make sure you angle the beam slightly down and to the left so you don't have the beam cut directly off in an oncoming drivers view.
    To quote Benboy:
    Any (ANY) modification(s), unless approved to ADR standards, that change/alter/modify any aspect of your vehicle from the ADR standards/requirements that existed at the time of manufacture of your vehicle are ILLEGAL.
    (Also, check this out )
    My 2007 WM Statesman
    BUY MY SURPLUS VE PARTS
    Leather steering wheel, GXP Diffuser, Nolathane bushes AND MORE!
    CLICK ME
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    A cheaper alternative but not as good as HID is to modify H9 60w globes to replace the H11 55w.
    They do make a difference but require you to remove a ridge in side the connector of the globe to enable the plug to fit.
    A narrow sharp chisel does the job quite easily.
    You can see whats needed when you look at both globes connections.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by Surfwagon View Post
    I did that when I had a VZ and it seemed to work pretty well for a cheap DIY mod.
    CLICK ME
    9/04 VZ Calais
    Jul 2009
    broadford
    thanks for the replies
    i will try the H9 and see how they go
    yep after reading a lot i understand that HID is illegal and in my job i cant do that
    thanks for the help
    cheers
    Rob
    05 VZ Berlina
    Mar 2010
    I gave up looking for non-expensive H11s from shops and got H9s from ebay. At least if they blow they're cheap.
    Did the H9 mod and made a difference. Also make sure the headlight aim is where it should be - pattern cutoff should drop 2 inches over 25 feet.
    Mine was off a bit - saggy front suspension?
    local http://shop.ebay.com.au/?_nkw=h9+65w...All-Categories
    O/S http://shop.ebay.com.au/?_nkw=h9+65w...s&LH_PrefLoc=2
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina VesperZ Executive
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Question to the OP... why are they blowing? Chances are if they are blowing there is a reason for it and therefore you should resolve the issue first, otherwise there is a high chance you will have the same issue regardless of whether you have HID's installed or not.
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
+ Reply to Thread
  1. VX Headlamp failure
    By OllieTwo in forum Electrical Wiring / Questions
    Last Post: 24-01-2010, 11:36 AM
  2. 2 gauges changing stock globes to led globes
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2009, 06:25 PM
  3. Need help changing green globes to blue globes in instrument cluster
    By GILLO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 10:40 PM
  4. Calais Map Light Globes
    By DanVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2008, 03:42 AM
  5. not sure how to chang globes on fog lights vy calais
    By vlturb in forum Electrical Wiring / Questions
    Last Post: 26-01-2008, 07:27 PM
