+ Reply to Thread
Results 1 to 6 of 6
Thread: Big Brakes
    VZ Senator Heavily Modified
    Sep 2010
    perth WA
    Default Big Brakes
    Gday to all. I have a question Im hoping someone can answer. I have a VZ Senator and it has a big brake kit. I am uncertain who put the kit together as it has 6 piston AP calipers up front with 365mm x 34mm DBA 7000 series rotors. The rears I have not measured yet but it has 4 piston AP calipers. Its due for some new front rotors. No problem getting the rotors but the hats are custom made and Im not sure what bolts were used and which ones to get to replace them. Is any one aware of these kits and who makes them up. Or better still tell me where i can buy the bolts from. (They appear to be different from DBA ones.) Thanks..
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    It sounds like you have the VZ HSV GTS AP kit fitted as fitted to the last of the Monaro based HSV coupe's.
    HSV | Holden Special Vehicles | Previous Models
    Try one of the specialist brake shops Cebco, Hoppers stoppers, Race brakes etc.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VZ AWD One Tonner
    Jul 2006
    VZ HSV's were available standard with the 6 piston AP Fronts, so it may not be a custom hate etc. It could just be the genuine setup, but you won't be able to replace the rotor without going through genuine, so the best thing to do is just to get a replacement DBA 5000 rotor to suit, then next time round you'll be able to just replace the rotor ring. New slotted rotors (with hat) are $609 each, then later on the replacement rings are $409 each.
    Or you could have definitely completely different, as HSV never had a 34mm rotor standard (maximum has been 32mm), and the 6 piston AP's came on a 362mm rotor, not a 365mm...
    Gonna need some more details....
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Sep 2010
    perth WA
    Rotor part no is DBA 7870sl and 7870sr (left and right) calipers are cp5555. They are def 365 x 34. Dba 5000 don't fit and the vz 6 piston pads are completely different.
    Sep 2010
    perth WA
    Quote Originally Posted by Surfwagon View Post
    Thanks for the reply. I called racebrakes today and it is there kit they have made. The rotors are made by dba for racebrakes. Got the nuts being freighted over. Prob solved. Cheers fellas..
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Glad to see you were able to find the source and get them fixed ok.
+ Reply to Thread
  1. Brakes?
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2009, 07:36 PM
  2. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 08:34 AM
  3. brakes
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2006, 09:00 PM
  4. vk/vl brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2006, 03:55 PM
  5. vt brakes on2 vl
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-01-2006, 11:28 PM
