+ Reply to Thread
Results 1 to 6 of 6
Thread: Alloytec hard to start after sitting for awhile
    vz berlina
    Sep 2010
    echuca
    Default Alloytec hard to start after sitting for awhile
    My Vz berlina cranks over 5 to 6 times before starting if it have been sitting for an hour or more, if i shut off the car and start it again theres no problem! its as tho the fuel pressure is depleting back to the tank. i have had the fuel pump and filter replaced less than 10k ago and changed the plugs. ive tryed all diffrent types of fuels also. trying to get an adaptor for my fuel pressure gauge to see if it is holding pressure. anyone come across this? im thinking leaking injector or faulty fuel pressure reg ( ruled out fuel pump return ballbearing valve as it was replaced not long ago)
    Phyco's Avatar
    Phyco is offline Alloytec and Proud Phyco Executive
    06 VZ Acclaim Sedan
    Mar 2009
    WA
    How many KMs has the car done? Could possibly be the Spark Plugs if they haven't been replaced within the advised range... Doesn't make the most sense seeing as it starts fine after only short periods of time, but it's the first thing I thought of!
    -My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
    vz berlina
    Sep 2010
    echuca
    its done 145,000kms, as stated above they were replaced and doesnt fit with it starting fine after intial start up. im almost certain it has to be fuel related because it starts perfect the second time round. its as like the fuel pressure in the rail is slowly depleting. sounds the same as when you replace your fuel filter it has to regain the pressure again. i cant seem to find the fitment for my fuel pressure gauge to check tho
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja Little Red VZ Go-Kart Executive
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    VZ, like many others, has auto-start: quick flip of key and release will start the engine in all conditions. If it does not start like this, a problem does exist. It could be the starter motor, injector relay or fuel pump (which would be making a whining sound). A fuel pump will also have an unstable delivery to the engine, causing odd starting/restarting behaviour, hesitation, puttering and stalling at low (idle) RPM — maybe this is where you should start sleuthing before moving to the engine.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    VZ SV6
    Apr 2011
    Bundy
    Hello
    Just wondering if you have fixed your problem.
    Im having the same problem with my SV6 at the moment.....
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon andyman Senator andyman Senator andyman Senator
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    fuel pressure regulator is in the tank its fedd from that tee piece that comes off the filter inlet, try turning the ignition off and on a couple of times and see if the problem is reduced
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
+ Reply to Thread
  1. VP V6 Hard To Start - Help
    By oldfart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2010, 05:39 PM
  2. Alloytec engine clattering on start-up
    By twb1979 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-03-2010, 05:20 PM
  3. Hard to start
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2007, 03:51 PM
  4. hard to start
    By ads72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 12:33 PM
  5. Vr Hard to start
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 07:14 PM
