Results 1 to 2 of 2
Thread: transmission line on sv6
    vz sv6
    Dec 2008
    Default transmission line on sv6
    just a quick one does any one know if the flexible line going from the transmission metal lines, to the radiator can be cut.i am fitting a transmission cooler in, or is there a batter way of tapping in. sv6 has crimped lines .
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Yes they can be. Don't forget to leave the radiator trans cooler connected. Doing so will assist engine reaching operating temperature as designed by Holden and will also assist with trans cooling along with the new one you intend to install.
  1. Transmission pump out line to cooler.
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2011, 04:47 PM
  2. Transmission send line VT 5.0
    By Weapady Weps in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2010, 12:35 PM
  3. Disconnecting transmission line.
    By IPCOlsenVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2010, 10:40 AM
  4. VN Transmission return line
    By LindasBT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 08:40 AM
