Results 1 to 3 of 3
Thread: Post LPG conversion question
    VZ Exec Wagon & VTII S
    Aug 2010
    Default Post LPG conversion question
    I just bought an 07 VZ wagon that has been converted to LPG. The gauge has 4 LCD lights which doesn't seem that helpful. When I start it up it starts on petrol and switches over automatically when it warms up. Two questions:
    1. When I run out of LPG will it automatically switch back to petrol?
    2. Can I get a more accurate gauge installed?
    Thanks heaps
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Answer for Q1: If you run out of LPG whilst running on LPG, the gas ECU will automatically change over to petrol. When this occurs, the beeper will operate (it will drive you nuts when it does), to indicate that it has changed over to petrol. The only way to shut the beeper up in this condition is to flick the gas/petrol switch to the petrol position. Obviously, refilling the gas tank will do the same thing, but the beeper will have driven you insane well before then LOL.
    Answer for Q2: The 4 content gauge LEDs are driven directly by the ECU which in turn, gets the quantity information from the quantity sensing float in the gas tank. I'm not sure if you could wire up another gauge directly across the quantity sensing float potentiometer. I have however made up an LED repeater setup, that mounts in the vacant holes of the climate control internal air sensor mounting point (my VZ doesn't have climate control). Makes the gas status & quantity a hell of a lot easier to see, especially in bright sunlight, as they are directly in front of you. PM me if you want details.
    Attached Thumbnails Attached Thumbnails Post LPG conversion question-08092010-009-.jpg
    Aug 2010
    Thanks for the answers!!!
  1. post your vr/vs vx conversion bodykit pics
    By madvrcom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2009, 07:49 PM
  2. Simple exhaust question (first post)
    By jonesy23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2008, 09:34 PM
  3. right area to post question?/
    By GreendragonDMX in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-10-2008, 11:59 PM
Tags for this Thread
