Results 1 to 7 of 7
Thread: VZ- Fuel smell in cabin
    VT executive
    Mar 2006
    Smile VZ- Fuel smell in cabin
    G'day,
    I get the occassional fuel smell in the cabin.
    It's more common when the tanks above half.
    I've done all the easy things like getting new fuel cap, checking the fuel lines in the engine compartment.
    I'm thinking it may be a problem at the tank end.
    How hard is it to drop the tank?
    Any tricks or tips?
    Thought i'd ask you blokes before i have a crack at it.
    Thanks.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    With mine I found it wasn't so much getting a new cap - as tightening the old one.
    Just don't rely on hearing the clicks. After the clicking, grap the outside circumference of the cap & squeezing inward, physically turn it a bit more so that it seals tight.
    Should fix the problem. Does for most people.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Exactly as stated above only make sure that after you think it is tight turn it a few more times.
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    If the VZ's are anything like my mates VT they'll have a charcoal canister in the rear above the diff cradle which the breather hoses go to. if this is cracked or the hoses to it then you will get fuel vapour smells.
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VT executive
    Mar 2006
    You blokes are magic !!
    I gave the fuel cap a few harder turns .... problem solved!
    I wish all my problems were that easy!
    Thanks.
  1. Fuel smell in cabin
    By wickann15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2010, 06:53 PM
  2. Cabin Fuel Smell
    By NIVSSZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-01-2010, 03:22 AM
  3. bad fuel smell in cabin
    By camvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2009, 08:54 AM
  4. vr fuel smell in cabin
    By vr piggy bank in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 08:48 PM
  5. 96 VS UTE - Fuel smell in cabin
    By cleggy88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2006, 09:57 PM
Tags for this Thread
