I was just having a flick through my VZ SV6 owners manual and came to the section where it showed all the computer functions such as digital speed ON or OFF, rest reminder ON or OFF etc.
The problem is, i wanted to change how the drivers door unlocks first then all the others after another click so i would have them unlocking all at once, ive gone through my car's menu and it seems like that setting isn't in there, aswell as the headlight setting, locking indicator and a few more.
just wondering if im doing something wrong or anything, cheers.
do you have the stock headunit in or an aftermarket one?
Sounds like you a deadlocking the car as opposed to locking normally, or two-stage unlock has been enabled on the computer (through MODE).
Lock+Lock = Engages deadlock (electronic jamming)
Unlock (once) = unlock driver's door while other doors remain deadlocked
Unlock+Unlock = Disengages deadlock from all doors.
When deadlock is engaged the indicators will remain on for a few more seconds than normal locking.
•:*¨¨*:•.When you start your car, does it return the favour?•:*¨¨*:•.
Originally posted by soop
Your arse is going to sting for a while, and then worse when it does bugger all.![]()
aftermarket, i thought that i would be unable to see some of the features that had stuff to do with the stock head unit but i didnt think it would matter for things like the doors locking and to choose whether you'd like just indicators or indicators and beep when locking.
you can only acces this menu after you turn the key, after the holden check it says push one of the arrows and it drops u into a sub menue then u scroll through the options using the mode button and arrows.. hope this helps
pretty sure you cant get to alot of functions without the stock headunit. if you really want to get to the menu, just chuck in the stock headunit, change the settings you want and then put ur aftermarket one back in
or...
...the menu can also be entered by pressing and holding MODE while turning the key to ON to enter the menu system (no start needed).
Just a passing note that if you have POLICE MODE engaged then some menu items will not be available (this is surprisingly very common with people buying from Services fleets). Best to remove POLICE MODE as it has no benefit; a techie will do that with his plug-in.
when ive entered the selection bit, these are the only features i can choose from...
Restore to factory settings (NO - YES)
Underspeed chime (ON - OFF)
Dist. to go display (ON - OFF)
Stop watch (ON - OFF)
Rest reminder (ON - OFF)
Digital speed (ON - OFF)
Exit options menu (YES - NO)
best bet would be to throw in the stoock unit and then change them to what you want, then change it again
so you reckon thats what it is?, funny thing is my mate whos got a vz calais with an aftermarket head unit in still has all the features.
just out of curiosity, whats your ver: (version number), serial no: and gm part no: when you turn the key with the two buttons pressed?
not saying that it is it, just everyone knows some of the features are disabled, and its easy to just change them over just to see.
yeah fair enough, its not something thats really bothering me or anything but i just wanted to know what was going on.
it shows my current version as 000.027.000, so i dont know if that means anything. if i was to go down to Holden what would i ask em to do for me?
just tell them that you've put an aftermarket head unit in and have lost some of the functions in the hidden menu, they'll be able to sort it out for ya
Chev badges are an instant fail
I have the exact same problem as the op and every holden dealership I have contacted has told me there is no other firmware and that I just have to put up with it.
What is this magical firmware everyone keeps suggesting? Have people actually had this done to their Vz's?
Any help would be greatly appreciated.
Well i took it down to my local holden dealer and that was a waste of time..i had to speak to three different people for some guy to understand my problem. They all thought i didnt know how to turn the fuctions on but i was sitting there telling them that THE FUNCTIONS ARNT THERE...
But anyway in the end the bloke said hes never seen this happen before and that i should take it back to whoever did my stereo install? :/ (asif they would know)
I asked about the re-flashing of the software and they reckon it wouldnt do anything...now what?
just tell them to do it, whether it does anything or not. obviously depending how much it costs
unfortunately on some models if ya change the head unit over you do loose some features like locking and there is noting Holden's can do there is no magical firmware upgrade
they told me it would be $65 to hook it up to their computer tool or whatever, i guess thats how much a re-flash would cost.
