Results 1 to 14 of 14
Thread: VZ SS FUEL evaporation
    BLOWN VS
    Jun 2005
    Cairns
    Default VZ SS FUEL evaporation
    hey guys jus have a fueal issue i want to resolve.
    filled up 2day with 2km to go until empty but it only took 39L to fill up. i'm guessing VZ SS's only have a 40L tank??? and once filled it shows about 610km until empty but bout 280-310km later its empty again. now surely any fuel tank would last longer than that even if you drill a hole in it....
    Check out my ryde!!!
    http://www.cardomain.com/ride/2040074
    ohhh yeah.....only milk and juice come in 2 litres
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    sounds like the problem vz utes had, if that helps
    Spoken by a true member of The Committee
    BLOWN VS
    Jun 2005
    Cairns
    and what was that problem??
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Inaccurate fuel gauge. Fuel tank is actually 75 litres but will read 0 distance to empty when it has only used about 50 litres. I've gone another 100kms after 0 to empty and it has still only taken 61 litres. I think it is set up like this to keep the fuel pump submerged therefore stopping it from burning out prematurely.
    BLOWN VS
    Jun 2005
    Cairns
    so is ther anyway of fixing this problem??
    Oct 2006
    Bogan enclave
    I believe the 3 window cluster fitted to the Calais can be calibrated by the user but otherwise there isn't a fix no.
    May 2009
    Gold Coast
    cant you take it to holden and get the software updated
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    It would sound more like it's a safeguard against driving empty, not a software problem that needs updating.
    You can likely get around 50km in the 'red zone' but commonsense would say plan ahead and fill up rather than take your chance. Emptying the tank in the middle of bloody nowhere is not funny.
    Bravotwozero virtually nailed it re the fuel pump. I frequently drove very close to or on empty in my old car and went through 2 fuel pumps! It was explained to me (2000-2002) if you frequently drive on a totally empty tank, the fuel pump will not come out of that unscathed, worse if the car is angled and remaining petrol has drained away from the pump (e.g. NO START): it does need fuel to work, not air. Most VZs have a LOW FUEL warning on the dash display; I refill mine just below the second last (red) tick as usually I extend my travels without planning.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
    BLOWN VS
    Jun 2005
    Cairns
    yes but as i said it was showing LOW FUEL with 2km to go and also i had only travelled 312km highway driving , but when i filled it up it only took 39L...... so it shoud still have 36L in it, thats one big bloody safeguard. obviously the standard fuel pump is complete shit if thats wat causes the stupid readings
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Could be a bent float arm, but this is generally evident from new.
    Could be a calibration or sender issue..
    When mines around empty it takes 60 litres or more.... definately not a 40 litre tank, closer to 75 from memory.
    Silver Certified.
    VZ SV6
    Oct 2008
    Newcastle NSW
    mine says 12 kilometres DTE and 3 Litres remainging in the diagnostic mode but only takes 54 litres to fill up (there's still 21 litres in the tank in other words)
    BLOWN VS
    Jun 2005
    Cairns
    what would be the ultimate fix? does anyone know of any holden tech/mech on this forum??
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Needs to be diagnosed to be fixed.
    Unfortunate part is diagnosis isnt free, so you pay for that, then whatever parts/action is required to resolve the issue.
    Basically you need to book it in to either a Holden dealership or someone that knows Holdens.
    Silver Certified.
    BLOWN VS
    Jun 2005
    Cairns
    cheers mate
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
