Results 1 to 4 of 4
Thread: High Flow Cats
    VZ SV6 but have owned VC,VK,VL,VP,VT
    Sep 2009
    South East Queensland
    Default High Flow Cats
    I have been told that if I get high flow cats installed that the engine lights may come on and if thats the case it will be $1000 for a tune up. Can someone shed some light on this for me? Is that right? and if so why would it cost so much for the tune?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    If your car is equipped with before and after cat O2's then yes you may need a tune but won't neccessarily mean $1000.
    The mafless dyno tune on my LS2 only cost $850 and there is a lot more involved in changing over to mafless than just a straight tune to adjust for higer flowing cats.
    Are you doing the rest of the exhaust at the same time or is that already done.
    BTW it will still drive ok with the engine light on.
    On LS# engines with 4 x O2's they usually turn off the rear O2's as they are only there to check that the O@'s are working as its the fronts that actually adjust the mixtures.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Sep 2009
    High the car already has a 2.5 single sports system and we are getting headers and high flow cats..it was the exhaust shop that quoted the $1000..so maybe we should shop around??
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Quote Originally Posted by MissSV6 View Post
    I had heard the same story, however I have just put "Hurricane" Extractors & 3" oulet into 100 cell High Flow Cats & & then full "Xforce" stainless 3" cat back dual exhaust thru to the dual 3" outets on my VZ Monaro LS1 & there's no light coming on at all ,& boy does it run & sound great too!!!!! I am extremely happy with the result. Maybe it depends on the system you use , some do some dont. Go ahead & do it , chances are it will be fine......
LinkBacks (?)
  1. 26-10-2010, 11:46 AM
  1. High Flow Cats, worth it?
    By Anwyll in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2010, 09:10 PM
  2. Difillipo Extractors and High Flow Cats
    By bluevzssute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-07-2009, 06:55 PM
  3. High flow cats
    By H1GHROLLR in forum LSx Development and Modification
    Last Post: 01-03-2009, 07:53 PM
  4. What high flow cats to use??
    By Breno in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2009, 05:24 PM
  5. High flow cats and extractors
    By gamevx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2007, 07:54 PM
