Results 1 to 2 of 2
Thread: central locking problems
    vz adventure
    Sep 2010
    BALLARAT
    Default central locking problems
    hi,
    i have a problem with my central locking on my vz adventure. sometimes when i press the remote to either lock or unlock the doors the drivers side indicators stay on and will only turn off but continually locking and unlocking doors until it goes off.....
    has any one had this problem and can any one help????
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Given recent street corner discussions I've bumped into, have you at some stage confused the locking cycle and are now stuck in a deadlocking cycle? The behaviour of the indicators changes for deadlocking as opposed to normal lock/unlock. When deadlock is engaged, the indicators will stay on a bit longer, then go off. In the last few weeks I have been profoundly amazed that many, many Holden owners are inadvertantly engaging deadlocking and confusing themselves (and the car's BCM!). Even my Holden techie got a giggle, but he said it's caused by drivers not familiarising themselves with the two locking types available, or forgetfully pressing lock twice then a third time. I think the car (->BCM that controls central locking) needs to be "rested" for about 15 minutes to reset, otherwise a service/check with the tech instrument would be wise to sort it (and the driver!) out. This implies that if you are not in difficulty with deadlocking, then the BCM needs a walk-through to ensure a fault hasn't developed.
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
LinkBacks (?)
  1. vt central locking problems
    By 98vtberinla in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2010, 08:59 PM
  2. central locking problems
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2008, 09:43 PM
  3. Central Locking Kit Problems
    By caekmaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2008, 07:37 PM
  4. Central Locking - Key problems
    By swirldog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2006, 03:20 PM
  5. Central Locking Problems
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 09:20 PM
