was thinking about installing some door courtesy lights into the doors in my VZ SS, but just wanted to ask if there is current wiring in there within the loom, I'm not sure if my SS is in the high or low series of looms, or possibly medium. I currently have the 'above the door where the handles is' courtesy lights if that helps with whether it may or may not be.
i did the same on my vy...
but i parallel circuited the dome light wiries..
Yellow - Negative
Orange - Postive
hope this helps![]()
cheers bud, will I come across any problems if I wire the door courtesy and footwell light to the both headlining courtesy light sides.
did you put In the door lights, if so did you use your original skins, if so did it go well cutting the holes
edit: sorry double post
