Results 1 to 19 of 19
Thread: whistling sound when i throttle
    VZ v6 Executive alloytech 04
    May 2010
    Default whistling sound when i throttle
    hey got problem when i press the throttle i get a whistling sound from the engine anyone know what this might be and how to fix it
    thanks guys!
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    any chance your car is supercharged? if it is, take it off and give it to me, fixed!!
    Life starts at 200km/h
    May 2010
    nah mate not supercharged,i was thinking it might be fan belt or the pulleys on the engine tried getting abit of wd40 but nothing,have to take engine cover of to give them a good spray!
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    If you havent already check a hole in your exhaust, is it a whistle or a squeel?
    May 2010
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    After playing around with my stereo today i developed a whistle aswell, i know what the problem is but maybe you could have the same issue
    2005 VZ Acclaim
    Jul 2009
    Northern Beaches, Sydney.
    im actually having the same problem and it differs on a day to day basis regarding the noise
    any help would be appreciated!!
    VR Berlina
    Mar 2010
    sa
    May 2010
    ant anyone got the answer its rather annoying me,i ant touched my sterio lately so wouldnt be that!
    Ryley's Avatar
    Ryley is offline VZSV6
    VZ SV6
    Jun 2010
    Two Rocks/WA
    I have this problem, and have realised it's my air intake - due to it getting louder when I go faster!
    Reppin' Alloytech 190/5 Speed Automatics.
    05 VZ Berlina
    Mar 2010
    Mine was sounding like a sewing machine when I got it. They had put the corrugated section of the air intake on back-to-front, causing an air leak and the noise. Fixed it, noise gone.
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    May 2010
    still got the whistling sound any more info on what it could be in getting concerned more now!
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    um try checking the vacum lines on throttle body (underneath it on v6) it runs to the back of the manifold aswell
    on v8 the big long pcv hoses rocker to throttle for holes
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    better take it to a mechanic and just ask them what it sounds like if your too worried. im sure one of these guys on the forum in your area would be happy to have a listen
    Spoken by a true member of The Committee
  15. #15
    VX Commodore
    Sep 2010
    VIC melb
    My thoughts it could be either your air intake or your pulleys, Mine whistles when i accelerate but I know its my air intake haha
    Yeah man as Richard said just take it to a mechanic if your worried
  16. #16
    VZ SV6
    Sep 2010
    hey guys, i noticed today that my engine squeels too, i had a listen and think its either the belts or the pulleys :S
  17. #17
    May 2009
    Gold Coast
    Quote Originally Posted by 04sv6 View Post
    get a long metal rod or something similar and put it on the pulleys and put ur ear at the other end of the rod. the sound will travel up the steel like a stethiscope. just dont hurt yourself in the process. i think pulleys are like 40 bux from memory
  18. #18
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    PERFECT richard this is the correct way to check individual pulleys
    if you pull the drive belt off and start the car the noise should be gone if it is gone then you know where to start looking
    if its not gone go to mechanic to diagnose or fix
    there is a note here on your car though!
    the power steering pump pulley on these is adjustable (with right tools) so that it perfectly lines up with other pulleys sometimes (a lot of times)
    this is the cause of noise "misalignment" if no pulleys sound WAY louder than others then this is worth a check.
    pulley misalignment on p-steer pump is normal though and happens with time and lots of hot cold hot cold like driving your car to work in the morning they dont replace it only adjust it (normally)
  19. #19
    VZ SV6
    Sep 2010
    Quote Originally Posted by richardpalinkas View Post
    beauty, thanks for that mate, ill sus it out first thing in the morning
  1. Vt V6 hissing sound under light throttle
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2011, 08:51 AM
  2. Creaking Sound From Throttle Body
    By Blocka111 in forum General Discussion
    Last Post: 25-08-2009, 07:03 PM
  3. Air Intake / Throttle Body Sound
    By Noel-e in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2009, 10:34 PM
  4. strange whistling sound?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 06:54 PM
  5. Whistling Sound from my VR?
    By NXNVR-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2005, 07:04 PM
