Results 1 to 8 of 8
Thread: Brake pad failure
    V6 VT series 2, V6 VZ Calais
    Aug 2009
    Default Brake pad failure
    Hello. I thought I might share this one as it does highlight one of the most important safety aspects of your car...the brakes and their servicing.
    The other day I noticed a slight grinding noise when touching the brake so I decided to check. With the wheels still on I could see on the rear the outer pad thickness was down but still ok (about 5mm left). the fronts were still quite good (8 - 9 mm). I pulled the rear wheels off for a closer inspection and to my astonishment I found that the inner pad lining had become completely detached from the pad/plate which resulted in metal to metal contact. I found the piece sitting between the disc and the backing plate.
    The thickness of the lining was still around 5mm. Pretty much minimum but to have it fail like that is something I never considered when I last inspected them 8,000kms earlier. I've seen failure like this with drum brake shoes before but never a disc pad. Poor quality? Heat related? Who knows?
    With servicing intervals now every 15,000kms (not 10,000kms like they used to be), one needs to be a bit more conservative and change them out sooner rather than later.
    Food for thought.
    vz v8 wanna be
    Sep 2010
    caloundra
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Aug 2009
    I don't know. I wish I knew so I could avoid getting them. I replaced them with Bendix Ultra Premium. I trust these are good.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Had an african bloke come in complaining of noisy brakes.
    The pad had worn down to the metal, then though the metal, then through a good part of the pistons.
    Unbelieveable.
    Silver Certified.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    My service intervals are every 5,000 km. With vehicle safety there's absolutely nothing you can take for granted.
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    Quote Originally Posted by RiCeY View Post
    Unbelieveable.
    ROFL... Moron african...
  1. possible brake failure?
    By Static89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2009, 10:18 AM
  2. Brake failure wtf :)?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2009, 10:01 AM
  3. tail/brake light bulb failure
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 07:15 AM
  4. Brake Light Failure
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2006, 07:28 PM
  5. Brake failure
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 12:18 PM
